Allis ib rear rims |
Stookless ![]() Bronze Level ![]() Joined: 11 Jan 2019 Location: 46759 Points: 98 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jan 2020 at 8:20am |
Does anyone know the correct rim type for the rear of a IB? Mine has the 4 bolt on one side and the continuous bump on the other. Then there is the 4 bump rim. Which would be factory original?
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12002 |
If I remember correctly, my IB had the four rim bolt clamps like my B had. Nothin' trick about it. Coarse, over the years, things get changed around, so one of your wheels may have been a replacement to the original if one of the wheels was rusted out or damaged....
Steve@B&B
Yes it does have the four bolt eccentric on one side like a normal b, but the rim is the different part being that the bump goes all the way around instead of 4 seperate bumps.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87947 |
what year ? ALLIS changed over the life of the B and C... the IB was not special, just depends on the year.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5026 |
My IB has the same rims (4 bump) as my B's.
Does anyone have an extra set of decent IB fenders to sell ????? Edited by WF owner - 08 Jan 2020 at 8:49am |
It is IB #3506. Not sure of the year.
According to TractorData.com, 1953 was the last year of IB production and 1953 started with IB2570. They also say there were 2850 built. As with many models, serial numbers started with 1001. I'm quite sure (and someone can correct me if I'm wrong) that pre-1946 models used model B serial numbers.
Production of the IB in the 50's were usually under 400 per year, so I find it hard to believe they built over 700 in the last year of production. (Maybe???) Here's the link to Tractor Data:
Edited by WF owner - 08 Jan 2020 at 11:04am |
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3090 |
Maybe it was built when they changed from one style rim to other.
