Allis HG Any good
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: Allis HG Any good
    Posted: 16 Jul 2018 at 7:03am
Theres a local sale with an allis hG track loader on the list. JUST wondered how hard parts areto find for it and how good of a machine it was when it came out and if oher allis crawlers machines parts will transfer, thanks   norm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 8:26am
what is an HG?
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 6:26pm
I meant 6g. sorry about that
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 6:33pm
The hd6g is good machine and  the track can be found but not easy and for the other parts  they are easy to found.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 9:58pm
I had some. The later ones are a little better than the early ones. Later ones had a bigger crank shaft, mine seemed to start real good. I know the later ones had a decelerator peddle, helps when loading trucks. Later ones had more rollers on the tracks. Mine were very dependable. If you ever put a main clutch in one, be sure to adjust the clutch brake. The last one I had, I bought it with a "bad injector pump". The guy lied to me, it ran on 3 cylinders, it had a hole in the block behind the pump. I picked up a motor out of a late hd6 crawler. It was quite a bit higher HP than the old motor. Would easily spin the tracks.
