Allis HD21 Starter
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Topic: Allis HD21 Starter
    Posted: 30 Jan 2014 at 2:05pm
Do any of you guys know  for a early 1955 HD21/HD16 starter with 12 teeth on the Bendix for the Buda engine ideally a foot operated starter would be great but any leads would help.Engine is a HDS 844 Prior to serial no 90001.
regards.
Mark
Edited by everett048 - 30 Jan 2014 at 2:22pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2014 at 2:15pm
HD-2173-6821000 DIESELDELCO SYSTEMDR2450MT1109986AHSDR0149
HD-2173-6821000 DIESELDELCO SYSTEMDR2440MT1113898AHSDR0017
HD-2167-6021000 DIESELDELCO SYSTEMDR2450MT1109986AHSDR0149
HD-21G70-6821000 DIESELDELCO SYSTEMDR2450MT1109986AHSDR0149
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2014 at 2:17pm
Looks like one could use a 50MT or 40 MT starter motor and just replace the drive to 12 tooth .
It would be a new style starter with solenoid rather than foot switch
The new Titan™125 Series starter motors are designed specifically for large bore diesel
engines up to 16 Liters.
12 Volt Applications
12V CW 14 1.909”
48.5mm
M125600
Mod 3
292.5o
50.58
Front View Details Teeth
Pitch Pinion at rest
Pinion Details
OD
82.5o
12V CW 11 1.909”
48.5mm
M125601
6/8 46.5mm
Pinion Details
OD
12V CW 11 1.909”
48.5mm
M125632
6/8 57.6mm
Pinion Details
OD
12V CW 12 1.909”
48.5mm
M125634
8/10 46.3mm
Pinion Details
ODwww.prestolite.com 9
The new Titan™125 Series starter motors are designed to cross reference the following
competitor models:
12 Volt C
Edited by Coke-in-MN - 30 Jan 2014 at 2:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2014 at 2:21pm
Thanks Coke i have just got some more info on it,it was made in 1955 fitted with a HDS 844 motor.
regards.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2014 at 7:52pm
i have a parts HD16 with lanova engine should be same as HD21 engine but no supercharger.  you looking for complete starter or just bendix gear?  ill have to check the machine, dont recall for sure what i have.
Edited by CAL(KS) - 30 Jan 2014 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 1:39am
Cal it is not for me a collector over here is looking for the correct 1 to put back on his 1955 hd21 with the 844 hds motor in it (foot operated)
regards
Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 12:21pm
After rebuilding my HD5 starter several times - the last time I went to the 40MT starter as field coils in original unit went bad and finding those came out to about same price as fully rebuilt late style.
 Having a solenoid to advance the drive unit into flywheel rather than foot lever has worked great for me.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 12:52pm
Dave, I can get a new starter. Have Arthur call me later.
norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 2:59pm
Norm i will ring Arthur tonight.
regards
Mark
