Allis hammers DD Motorgrader
Blanco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blanco Quote  Post ReplyReply Direct Link To This Post Topic: Allis hammers DD Motorgrader
    Posted: 01 Dec 2017 at 10:48pm
Installing cab heater in unit, would like pictures or exactly where factory hook up of hoses should be on the engine. Have had some general suggestions that to this point have not allowed for good circulation of hot water.
Appreciate the imsight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blanco Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 4:58pm
Afternoon,
Does anyone have a DD Motorgrader (262 Diesel Engine) with a cab heater? My post has been viewed and I'm hopeful there is a unit out there that has a properly functioning heater.
My block will heat up just cant get circulation thru heater core.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 5:28pm
Pull th heater core. If it's bad a good rad shop should be able to match it up.
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 7:06pm
Unhook both hoses from the heat, loop them together with a piece of copper pipe  see if hoses get hot !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blanco Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 10:36am
I have a brand new heater core assembly so its in good shape, I am challenged by the correct location around the water pump to make my connection. The grader is number 1575 so it has the cast wishbone coming from the bottom of the radiator to the water pump, then goes up to the casting that is fed under the thermostat by a 1" line. I have even Tee'd into this 1" line to try to achieve flow and wherever I am connected I have pressure and not developing a flow with the warm water in the block. There in lies my challenge, and why I am hoping a specific picture or diagram of the right connection can be found.
Thanks in advance for those who are reaching out to try to help me in solving this problem.
Blanco
This page was generated in 0.207 seconds.
