allis H 10 DOZER
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: allis H 10 DOZER
    Posted: 10 Apr 2018 at 7:09am
Anyone have any information on this dozer, weight, hors power, shuttle valve or not. available parts. are they ant good, etc. All info is helpful. thanks norm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 7:57am
Gm 4-71 engine   98 pto/82 drawbar hp
weight 21-23000 lbs bare tractor
manual transmission  6F 2R  with the hi/low and master clutch
parts machines are pretty easy to come by,  engines are easy to get parts for since GM.
they have a monolithic powertrain.  very durable, but putting a clutch in means pulling the engine unlike later AC models, not a bad job though.  trans and rear end 1 casting.   single reduction final drives.
if abused and overworked the pinion gears tend to loose teeth, but depends on how it is treated.  we had one for many years and sold it to upgrade to a larger model.  I bought another a couple years ago and use it occasionally but also have a larger newer model.
they are slower and more cumbersome than newer models but with some patience and learning to use the machine within its design limits they can be productive for occasional use.  not something to use to make a living.
like any crawler, the undercarriage condition is important.
this is the one I currently have.  loaded to bring it home and after reworking the cutting bits on the blade and used a bit.
Edited by CAL(KS) - 10 Apr 2018 at 8:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 9:53am
Thanks for the info. am looking for a dozer to build a pond, mostly clay dirt. thanks norm
This page was generated in 0.154 seconds.
