Allis G Intermediate Clutch Brgs |
Post Reply |
K-Mo
Bronze Level Joined: 09 Feb 2013 Location: Atlantic, IA Points: 91 |
Posted: 27 Jan 2021 at 8:37am |
Can anyone help with replacement needle bearings and thrust washers for the intermediate clutch shaft on the Allis G? A couple of years ago, I replaced the needles bearing with Torrington B-1612. As I recall, that number was on the bearings I removed. However, the 1" outside diameter was too large to press into the gear. Ended up having the gear machined to accept the B-1612 bearing. |
K-Mo
CORRECTION-- The Torrington bearing OD is 1-1/4" OD, not 1". As I recall, the gear bore was only machined 0.002 or 0.003" to meet the bearing manufacturer's specs.
JoeM(GA)
Orange Level Joined: 12 Sep 2009 Location: Cumming,GA Points: 4517 |
Kent, 1612 is the notation I made in my parts book, I remember it being a pain
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21451 |
When I had my Willys 4WD pickup I did a 'mod' to the middle gear of the 'noisy' transfer case. It HAD a zilion needle bearings.'fun' to replace. The cure was to replace them with a couple roller bearings. I recall there was a minor machining needed and $10 for the Made in USA bearings( 1978ish). Once done,installed went for test drive.... I could talk in the cab ! No more shouting ! It should be possibel to do the same, only need 3 number OD,ID, W and search forbearinng(s) to fill the void. Jay
Post Reply | |
