Allis FWD 8050 Powershift Issues
devbow76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Topic: Allis FWD 8050 Powershift Issues
    Posted: 11 Nov 2025 at 9:28pm
Got a good one for you guys. Tractor quit moving so the powershift was pulled and hauled into the local dealer for a "rebuild". Got it back and installed it in the tractor. Worked for 5 hours then quit again. Dealer wouldn't warranty because they just got the powershift and not the whole tractor so we decided to split it. Found that there was multiple piston seals ripped. Replaced all the seals and reinstalled in the transmission. Its been working for over 50 hours now however its developed a random problem. It will be driving and happens in any range or powershift. It acts like someone shifted the transmission into neutral and it just coasts to a stop. The range and powershift were not moved nor the clutch pressed it will be driving just fine and then coast to a stop. If i mess with the range/powershift it will start going again. Sometimes its 5 minuets and sometimes its 45 minuets. Removed range transmission cover and when it acts up all the range gears stop turning but you can still hear the hum of the clutch drums turning so I'm convinced its in the powershift somewhere. Also when it acts up the steering, brakes, and pto all still work just wont move. All clutch pressures are perfect to spec when it acts up as well. Any ideas are greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2025 at 7:23am
Ripped or cut piston seals on one of those transmissions is the mark of someone who has never done one before. You have a hydraulic problem. Does the 1800 RPM light on the dash work?????????   I assume not. Get it fixed so we can diagnose what is going on. Was the Power Shift valve disassembled and gone thru ???????? Again, I assume not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 57 minutes ago at 10:04am
Sorry for the late reply I'm not very tech savvy. Checked pressure at all 1/8" pipe plugs for the a,b,c,d clutch's and when the tractor stops moving. Each clutch pressure does not drop. Stays good at 210psi which according to the manual is the correct pressure. Doesn't matter if the oil is cold or hot the result is still random. When the tractor stops moving with the range cover off of the top of the transmission. The gears stop turning but i can hear the hum of the powershift clutch packs still turning. It seems like there is a disconnect from the range transmission to the powershift. When i seen it split it looks like there was only a collar connecting the two but the splines were in great shape and there is no grinding noise at all when its driving or stopped. When i shift the powershift gears i can hear it shift in the powershift. rpm light on the dash works and does go out when required. Powershift valve was gone through and also replaced as the dealer had the parts cannon out .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 49 minutes ago at 11:12am
Well, you've determined the PST seems to be working. The range transmission can't if it isn't turning. Has to be coupler related, but how can it re-couple itself ??  And how can the output shaft to the PST just quit turning and then decide to start again ?? Sounds like a split it (again) in the future. If that coupling isn't bad on the front of the range tranny, then it must be in the PST but I'd have no idea what. Somebody has to be first. You're him.               EDIT:   I don't have my service book in front of me. It only takes TWO of the six clutch packs to make the tractor move forward or reverse. I know the C2 clutch is for reverse. I know the C1 clutch is one of the two "inching" clutches. There is one more "inching" clutch, but I don't remember its name. Anyway, both inching clutches are applied in 3RD gear. To fully diagnose this, I guess you need at least 5 test gauges all hooked up at once. C2 is only for reverse, so you might be able to skip that one. This has to be a hydraulic problem, and proper diagnosis is crucial to a good outcome. Love to help. Wish you were closer. Someone has missed something in the valve itself or the hydraulic application of clutch packs.
Edited by DrAllis - 12 hours 21 minutes ago at 12:40pm
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 36 minutes ago at 3:25pm
This may be out of left field. Just thinking of anything that might help. It semms to me the inching valve is dumping pressure on the clutches causing the tractor to stop. Sinc you have had it apart i think id go through the procedure to adjust the inching valve to factory spec. That thing is sensitve and it doesnt take much to throw it off. You may have slready done that i dont know. Trying to think of anything to keep you from having to split it again
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 3 minutes ago at 3:58pm
I will take any help at this point. My only question to that is i should see the clutch pressure in the a,b,c,d port drop shouldn't I?
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 58 minutes ago at 4:03pm
Ok i also agree that it seems the powershift is working but i find it weird how the coupler could come undone and then slide back on. I was wondering what connects the input shaft from the engine to the range transmission. Does it go flywheel clutch pack then output shaft of powershift, then coupler, then range. Like what's the path of power maybe that'll help pinpoint this. I would like multigauge set like that but i only have a single gauge set as the multi is pricy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 55 minutes ago at 4:06pm
I would also like to add the powershift pump has been flow and pressure tested passing with flying colors
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 54 minutes ago at 10:07pm
Actual clutch pressures will vary with oil temps and engine speed. 210 psi is fine. That isn't your problem. If it was under 100 psi there would be a problem.  Place the PST in 3RD gear and leave it there. It is almost mandatory to have TWO gauges, and a hose on each gauge. Wire the gauges to the head light or battery box or whatever, so that you can SEE the gauges while driving. Have the two gauges plugged into the C-1 test port and A-2 test port. Now, drive the tractor until it quits moving and tell me what the gauges say. The inching pedal must be fully UP !!  Any downward position of the inching pedal cuts off oil flow to C-1 and A-2 inching clutch packs. When the tractor quits moving does the red 1800 RPM light come on ??? and both gauges dip to zero ???
This page was generated in 0.069 seconds.
