Allis front end on truck |
Eric[IL]
Topic: Allis front end on truckPosted: 31 Aug 2011 at 12:10am |
I found this ad and just had to post it here. Its not my ad. I have never seen the front of an Allis Tractor for an older truck front end. I think it looks good. Here is the link:
scott
Joined: 12 Sep 2009 Location: michigan Points: 2769 |
Posted: 31 Aug 2011 at 5:49am |
Suppose that radiator is enough to cool a 350?
jccleav
Joined: 11 May 2011 Location: Indianola IA Points: 211 |
Posted: 31 Aug 2011 at 8:00am |
I liked the back window. I am also a Chevy guy.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Posted: 31 Aug 2011 at 5:38pm |
That radiator is probably more suited to it, than many newer radiators... it isn't, however, probably well suited to the pressurized-system application... <shrug> gotta try it to be sure.
What would make it COOL... is if he had a set of B/C/CA front wheels with tri-ribs on the frontend... and a turbo'd 406 underhood... And a hand-clutch... and a 3-point and PTO stickin' out the back!!! Edited by DaveKamp - 31 Aug 2011 at 5:39pm |
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 31 Aug 2011 at 5:54pm |
The radiator is probably the same size as the original. They normaly only. use the grill shell. The hood is Ford.
junkman
Joined: 02 Mar 2011 Location: Nevada, MO Points: 355 |
Posted: 31 Aug 2011 at 11:30pm |
A guy in town has the front half of a M Farmall on a truck back end. All fixed up with a nice flat bed on it. it has a wide front end but still utilizes the original motor. Don't look to bad.
