Allis F40 fork lift |
Post Reply | Page <1 91011 |
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8224 |
Dave,
Thank you for the details. I will try to learn some things and get this running better at some point. Regards, Chris
Sugarmaker
Folks,
The F40 has starting issues, Yea I have only done a farmers tune up, fixing a bare wire going into the distributor and cleaning the points, rotor and cap contacts. I am starting to fab the brackets to hold the gas tank. It has been setting on blocks of wood for a while. (I have to age these projects like fine wine):) If anyone knows the points, rotor and cap numbers please let me know. Regards, Chris and Cheryl
Sugarmaker
Eric B
Orange Level Joined: 09 Feb 2012 Location: British Columbi Points: 918 |
With the cap off you may find the distributor tag# if you can use a mirror to see around the back, if necessary. Of course better yet, if you pull the distributor out, as the digits are so small. If I remember right, I think the points are the same as in the Allis tractors. You could pull the cap off one of your tractors and compare.
Sugarmaker
Eric, Folks,
I will try those ideas, thank you! This cap has screws holding it to the base, compared to the other Allis tractors we have. I have a new set of points for the CA. I will look at those. Regards, Chris and Cheryl
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5309 |
Chris Here is a link to a Website that might be some help with your Forklift. G https://www.forkliftaction.com/forum/allis-chalmers-forklift-help.aspx?t=27489 |
Sugarmaker
Gary,
Thanks! I did look at that site. I need to do some more work to find tune up parts. That may help it start better! Regards, Chris and Cheryl
Sugarmaker
Folks,
Just playing in the shop. Added a little starting fluid and some choke and the F40 fired up quickly. Still doesnt seem to be charging at all when reved up, when checking on the battery terminals. I had replaced the alternator but fuel leaked into it, which may have not helped it? Also need to fiqure out how to check for alternator charging right at the alternator terminals to assure it is or is not working. It moves and lifts: Only yellow I had but the fuel tank is MUCH more secure: Regards, Chris and Cheryl
grizzzly
Bronze Level Joined: 16 Jul 2024 Location: socorro nm Points: 2 |
HI, is there anything between this outer plate and the drum with the gear in it to seal the dust out, mine appears to just have some grease (that also did a nice job of lubing the breaks)
grizzzly
here is a pic of my set up |
