Allis F40 fork lift |
Page <1 23456 11> |
Snowman ![]() Bronze Level ![]() ![]() Joined: 21 Jan 2020 Location: Phoenix AZ Points: 92 |
Let me try this again Ed
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8172 |
Ed.
Folks, Thanks for the pictures! Very detailed and I can see same things/ features on mine. My owners manual may come to me from friend Ted the Allis guy. He picked it up when it was going to be discarded at a shop he worked at. So you decided to put a bunch of money into yours. You must have the work for it or felt it was worth it? I am still learning about mine. Do you remember how long the pin was down into the blind hole? I was thinking of trying to drill a small hole at the end of the pin to get blaster into the cavity? You carb must be just for propane. Much different than my dual fuel carb. Good to see features. Ramps, blocking looks good too. Stout! Regards, Chris |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21759 |
I WAS going to post pictures of my ramps very simlar to what's been posted though ! but ... a certain 'he-who-shall-not-be-named' decided to test the long range abilty of his blasted machine........ |
Ever have things all typed up and hit some darn key and it all goes away: YEP You will have to fill in the words:
Found cavity at end of pin: The small .25 dia hole in the pivot block. The drill/hole saw coming through the side of the unit is where I will try to reach the end of the pin. ![]() Bored hole in skin: ![]() ![]() Drilled 3/8 hole through 2-1/2 inches of frame: ![]() Hit cavity at back of pin. Will drill larger hole for a drift to hit pin if my hole is accurate? May need heat and hammer action? Ed is right, both tilt cylinders need done. Probably hoses too! Ed can you get the kit number and supplier for the rebuild kits on these cylinders? Oh yea thats my new Dewalt light from Daughter Kelly! Also she got me a Dewalt Job site radio and I have been playing Chris Ledoux station on Pandora, very loud in the shop! Regards, Chris Edited by Sugarmaker - 27 Dec 2020 at 6:03pm |
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
I have not been following your post. If no one has posted yet, you can probably get a technical manual at themanualstore.com.
Tom,
Thanks! I did some additional drilling. May not look like much but I have reached the end of the pin that is stuck. I should be able to heat the pivot block and then hammer on it with a drift, or the air hammer?? Reminds me of the infamous WD brake pin!: Drilled almost perfectly into the cavity where the pin is. ![]() By the way I now own this unit. Figured I might as well get that paper work completed before the end of the year. Regards, Chris
Folks,
Small things! Here is that stuck pivot pin as it is driven out! ![]() ![]() Left tilt cylinder is on the bench for review. I need to clean it up and look for numbers stamped on the outside. Now to find rebuild kits. Currently working on removing the pin from the right lift cylinder. I got some movement from it so letting the Blaster soak in over night. Regards, Chris Edited by Sugarmaker - 28 Dec 2020 at 8:23pm |
sucess !! nice to see !!
Jay,
Folks, Got the other tilt cylinder off too. Not pretty! Got the numbers found on the cylinders. ![]() Approx distance to the rod to split clevis engagement: 1 inch plus ![]() The markingss;slightly different on each cylinder: ![]() Yea some clean up will be required. Have call in to local hydraulics shop. ![]() Will examine the hoses too. Regards, Chris
Edited by Sugarmaker - 29 Dec 2020 at 3:09pm |
Chris, yes decided to put some money into her, had it since 2005 and it has been a very good machine for me. I don't have seal kit numbers because I had them rebuilt by someone else. Glen over at forkliftpartssupply seems to be very good at finding parts. his e-mail is glennl@forkliftpartssupply.com. I have e-mailed him with the part I was looking for and he came up with the part number and price. i know he will need your S/N. Ed
Ed, Folks,
Thanks! I cleaned the years of gunk off the tilt cylinders and took them to a repair shop in Erie. Leo's is going to examine and quote a kit and also quote to do the complete rebuild on both cylinders too. Ball park pricing seems to be near your numbers too. I will probably let them do it. I really don't want to screw up a expensive seal. Which is just my luck! Also these are not in a easy place to get at. Ed, your pictures and info helped me on this F40 project. Regards, Chris |
Chris, If you need any other info I am more than willing to share what I know Ed
Folks,
Gave the hydraulic repair shop the go ahead to rebuild the tilt cylinders. They will rebuild test and warranty their work on these cylinders. Not cheap. About $300 each for parts and labor. (just about what Ed estimated) The seal kits were about $100 each if I wanted to do the rebuild myself. I just don't want to screw these up. I may look into the cost to replace the 4 or 5 hoses also. Again probably the right thing to do following Ed's lead. I am going to have some funds into this unit already and it hasn't done much yet! Ok I have a bunch of other toys just setting there not doing much too! ![]() Valve cover gasket coming from Sandy Lake. Same as a D15 Diesel engine. Regards, Chris |
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9795 |
But Chris you will enjoy having around and things it will do for you, them hoses will make it safer to work around.
im4racin ![]() Orange Level ![]() Joined: 12 Jun 2017 Location: Garrison ND Points: 866 |
Your chiropractor will thank you for having it!
Folks,
Freind Matt invited me to his shop so I took the broken pin and he made me a new one. ![]() Brought it home and its going to work just fine! I then fought with the F40 about tapping the 3/8 hole that I buggered up when trying to get the pin out! Finally got it cleaned up and re-tapped. Man it will nice to have some real lights in the shop someday! ![]() Just like new!: ![]() The last big heavy project provided me with the opportunity to blow out a disc and have back surgery! Trying to be a little more cafreful on things now. Happy New Year! Looking forward to 2021! Regards, Chris
Happy New Year to you and your family as well
Folks,
Broken bolt in top of F40 counter weight. Going to use these tapped holes to mount the frame work for the gas tank. ![]() I shocked this protruding 3/8 bolt with a couple hammer blows. welded a washer and nut on and it twisted off. Got a bigger washer and welded it and a nut on again. Let it cool and it wiggled and I new we had it! ![]() Got the new valve cover gasket but it needs stretched to allow a better fit. Doesn't have the side tabs to hold it in the valve cover. Will glue it to the valve cover. Regards, Chris
Well that sucks, the valve cover I got fit perfect
Ed, Folks,
Yes I seen yours and it has the tabs. This one is from a D15 Diesel I think and it is just a simple band. I will make it work, but that will be tomorrow after stretching it out to shape. I should get my cylinders near the end of this week. I plan to design/ build the gas tank mount this week too. May have to get some steel plate shapes. I forgot to ask on your ramps. does the forklift drive up each 1.5 inch step? Then you jack it up from there? I may have to build something like that? I have this feeling I may have to get safely under it for some work. Oh yea the brakes! Have to work on them at some point too. Big 69 today so I didnt do much. Wait that's normal! Have to get the hoses off and take them when I go to get the rebuilt cylinders too. Regards, Chris
JohnColo ![]() Orange Level ![]() ![]() Joined: 03 Apr 2020 Location: Niwot, CO Points: 1258 |
Happy Birthday Chris! Is the gasket made out of cork? If so, let it soak in water, it should expand a bit. A trick I learned from my day close to 60 years ago.
Page <1 23456 11> |
