Allis electric 2500 MPH-RPM tach
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Topic: Allis electric 2500 MPH-RPM tach
    Posted: 26 Aug 2010 at 7:46pm
  I bought a new nos allis tach there is 3 wire post hook ups on the back pos,nec and above them a 3rd post. I want to mount it on my pulling wd with a 1 wire alt.  think this is for a combine.  Any ideas?
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 7:53pm
  has to be late combine as the early ones were mechenical
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 8:03pm
pos to the dist side of coil
neg to chassis ground
3rd term for lamp
just my best guess
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 9:10pm
Watchya' figurin on doing 2500 MPH on?
I am still confident of this;
Wait for the Lord;
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 11:45pm
Lou, everybody knows Allis did do projects for NASA
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 1:17am
My engine analyzer tach has three wires.  Pos to positive side of the battery, Neg to ground, third wire to lug on side of distributor.
Bob, North Carolina
1949 B
BobH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 6:59am
Would early mech.tachs work on a D17?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 7:42am
 can't post any pics yet computer at home still down. there is a light that has a wire going to the positive post.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 8:00am
If it is for a late modle combine, it was made to work off of a sensor in the flywheel housing and counted notches in same. If this what you have it will not work on the inpulses from a distributor, also you need a tach that is able to calabrated for a four cylinder if you use one to the distributor. Most after market ones have seperate wires for 4,6,and 8 cylinder depending what you are going to install it on.
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 10:56am
me spewed coffee reading that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 1:26pm
Most 3 wire tachs usually have a green black & red wire. (not sure on an AC tach) Shouldn't matter what Alternator you have....
Green- trigger = to coil neg. side.  (with Neg. ground)
Black-  ground
Red-    12V Ignition source
cbt1124 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbt1124 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 1:47am
I think that the tach you are describing actually was wired into the alternator not the ignition. .If you have a single wire alternator you can just throw that Tach away.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 3:23am
Altenator on my 715B has another terminal on it for the tac. The regulator modual has 3 terminals on it.
 Body is a 10SI but has this modification
Edited by Coke-in-MN - 10 Sep 2010 at 3:24am
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
