Allis dozers in WW2
rwhendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwhendrix Quote  Post ReplyReply Direct Link To This Post Topic: Allis dozers in WW2
    Posted: 09 Jan 2014 at 8:54am
Hi, I have read that there were HD7s in lend lease and HD11 in the pacific theatre. Were all of them cable operated blades or were any of them ever loaders?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 9:07am
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 12:18pm
Interesting article, Steve.  HD11 wasn't produced until 1955.
everett048 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 2:50pm
I believe that HD7 W HD10 W and HD14 W where used in ww2 also WM crawlers were used as i have a service book for the M crawlers 1st edition with the U S war department order numbers on it.Also they were fitted with either a Carco C c u or Baker over head unit with front or rear mounted hydraulic pump, and equipped with la-plant choat blade? The WM crawler came equipped with and i quote Carco model e winch, 3 Man Seat.
Front mounted hydraulic pump                  Spark Plugs-4
Ice grouser shoes (skeleton)                      Oil Filter Element
Electric starting equipment                          Glass Sediment Bowls-2
Radiator curtain                                          DrawBar Pin
Muffler                                                       High  Nuts-8
Rear Drawbar                                             Track Shoe Bolts -8
Front Hook                                                 Track Shoes -2
Convertible Winter Cab                                Valve Springs-2
Vacuum Windshield Wiper                             Valve Tapers -4
Special Battery Insulation                              Fan Belt
Alemite Protectors                                         Chain Sling or Cable
150 ft of 5/8 " Cable                                   Single Pulley-Snatch Block
Hand Crank                                                Provisions for Carrying -Evans Burner         Crank Case Diluter
 Canvas Cover,Shove; Pick and connector for burner                                                    Tool Box on CAB
ON U.S. WAR DEPARTMENT ORDER NO. 58856-DA
Sorry for the long post
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwhendrix Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 10:47pm
OK thanks for the info. My mistake on HD14 instead of HD11.
I like the way they looked in the olive drab paint. My HD5 is too new, but it is needing a repaint and I am thinking of painting it this way instead of orange or yellow. Just think it would look cool and stand out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwhendrix Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 10:53pm
Heres a pic of my HD5G. It has the DD 2-71 and Tracmotive loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwhendrix Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 10:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2014 at 8:55pm
OK, ill bite... who is the little green guy next to the HD 5?
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2014 at 10:42pm
I'm going to guess an Oliver Cle track. I bet I misspelled it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwhendrix Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2014 at 8:12am
Yes its a cletrac built into a mini tank modeled after the WW1 FT17.
This page was generated in 0.180 seconds.
