allis D-17 series
tominMi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tominMi Quote  Post ReplyReply Direct Link To This Post Topic: allis D-17 series
    Posted: 15 Sep 2024 at 3:55pm
I have a 57 D-15 which I like for many reasons. It is a bit light HP wise to handle everything I need to do on our acreage. I'm considering a D-17 either diesel or gas. The early D-15's don't have what I describe as live hydraulics which makes loader work difficult. Some where I recall reading that Allis improved the hydraulics on the D Series to provide constant pressure whether the clutch was engaged or disengaged.
Do the later model D-17's have the upgraded hydraulics? Does any one know what year/ serial # determines the change from the old to the improved hydraulics?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 4:08pm
No D-15's have Live Hydraulics from the Factory.
Live Hydraulics can be added with a front mounted pump like the Model 415 Loader.
The last Model D-17, the D-17 Series IV has Live Hydraulics from the Factory.
The Live Pump is located on the R/H side of the Tractor where the Optional side belt pulley would be located.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote tominMi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 4:26pm
Thanks Gary. I see on tractor Data that production of the D-17 series IV began in 1964 w SN 75001.  Were there any additional improvements made in the later years 1966 thru 1967 that one would want?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 6:56pm
I believe the only other notable change was the availability of a rear 3 pt hitch as an option in place of the standard Snap Coupler.
G
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2024 at 7:00am
My recommendation would be to look for a D-17 Series 4 with a gasoline engine. Engine parts for the D-17 diesel are hard to find and expensive.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2024 at 11:14am
if you have facebook or know someone who does theres a few on there.
Link: https://www.facebook.com/share/bn68og6GnNFbi95y/ ; this one is in Michigan- looks nice to.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
