Allis cotton days
Post Options Post Options   Thanks (1) Thanks(1)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 7:57pm
Basically pickers are much more complicated than a stripper. Creston only had stripper machines. He has one with a header that looks like a pickers but it is not . Allis promoted strippers as a better more economical way of harvesting cotton. Another company (green) wanted the more complicated system that needed more replacement parts and service. This other company squashed research that Basically wrote the end of the stripper. Pickers produce a slightly cleaner product and can go through the field several times. Creston knows a lot about these machines and hopefully he can chime in. If you get a chance and he does this again definitely get out there to see this in person. Hopefully someone made a video that can be posted on YouTube of Creston explaining the machines and the process.
There are different varieties of cotton for both the pickers and strippers. Picker cotton is taller, usually irrigated and out produces stripper cotton. Stripper cotton is shorter and usually used in dry land farming. Produces less but much less input
Edited by Pat the Plumber CIL - 16 Nov 2025 at 8:02pm
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 9:45pm
Check out Wild West Farmer on YouTube!  They run 3 JD strippers that are 25 years old, still use boll buggies and module builders!  Says it is way to expensive to get a new one that puts out bales!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 4:52am
All of those old stripper teeth also have other uses, too...Wink
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 10:21am
There might even be one of those tree stands hiding here somewhere. But I believe that is picker spindle. Or do strippers use spindles too? Since picture of Creston's machines here is as close as I have been.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 11:56pm
Here are a couple clips from the show. It wasn't much, but we had fun! About 150 combined guests from both days. We had guests from Arizona, New Mexico, Texas, Oklahoma, Nebraska, North Dakota, Minnesota, Wisconsin, Illinois, Iowa, Indiana, Ohio, and Ontario. Everyone insisted I need to do this again next year, so that's currently the plan. Going to plan on November 13th & 14th, 2026.
A short clip of field demos and the kids' cotton picking contest:
This one is a walk-through history of the models of cotton strippers Allis produced:
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2025 at 5:43am
Pat, thank you for sharing info & photos. Will put this event on my calendar for 2026 & hopes to attend?
Creston, thank you for sharing a marvelous history of cotton production, both its industry & AC’s participation. I had read about AC using their gleaner machines as base models for cotton. Love hearing the G226 & GM250s running in the video & imagined smelling their gasoline exhausts? Terrific job!
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2025 at 2:53pm
Thanks for posting the videos for those of us who couldn't make it this year. We have cotton up here but I just haven't personally gotten to know anyone that raises it, so it's great to hear more about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2025 at 3:59pm
Creston, great job putting on the event, sounds like everything who made it had a great time and looking forward to attending next year. And thank you, Pat, for sharing the pictures. Nice to see all of those machines earning their keep. We have very little if any cotton grown in this area, it starts just south of here and the large acreage is in South Georgia.
robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robb Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 4:29pm
Here's some photos of an AC 801 picker we purchased new back in the 60's.  The main diiference between AC and Rust Pickers from JD and IH was the AC and Rust picked from one side with the picker spindles racks mounted on a top and bottom chain that pulled them thru the header and the JD and IH picked from both sides with the spindle racks mounted on durms that turned in and out of the cotton stalk as you drove down the row. The JD and IH had a suck/blow fan that carried the cotton to the basket.  The AC and Rust had a  blow only fan that blew the cotton in the basket when it was stripped off the spindles which resulted in less seed crackage because it was not going thru the fan.  The AC and Rust spindles had a right cut and left cut barb on them to grab the cotton and spin it out of the open boll.  You had be careful when replacing since one line rotated clockwise and the other line rotated counterclockwise.  They woud not pick if put in wrong. Later manufactured spindles had both a right and left barb on them so you couldn't put them in backwards.   The AC and Rust were good pickers and if setup right gave a cleaner cotton to gin, but the headers took a lot of maintance due to design and ware of parts.  The JD and IH were much easier to maintain and the headers lasted longer becasue they ran in oil sealed in the drums.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 6:27pm
Hmm….looks like someone needs to take that to next years show!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 6:59pm
That is awesome! I have never seen or heard about anyone having an 801 or 802 picker. So little info out there on AC pickers.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 7:33pm
Clever to realize they could machine a universal spindle for one part and error proof repairs.
