Allis cotton days |
Page <12 |
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4973 |
Thanks(1)
Posted: 16 Nov 2025 at 7:57pm |
Basically pickers are much more complicated than a stripper. Creston only had stripper machines. He has one with a header that looks like a pickers but it is not . Allis promoted strippers as a better more economical way of harvesting cotton. Another company (green) wanted the more complicated system that needed more replacement parts and service. This other company squashed research that Basically wrote the end of the stripper. Pickers produce a slightly cleaner product and can go through the field several times. Creston knows a lot about these machines and hopefully he can chime in. If you get a chance and he does this again definitely get out there to see this in person. Hopefully someone made a video that can be posted on YouTube of Creston explaining the machines and the process.
There are different varieties of cotton for both the pickers and strippers. Picker cotton is taller, usually irrigated and out produces stripper cotton. Stripper cotton is shorter and usually used in dry land farming. Produces less but much less input Edited by Pat the Plumber CIL - 16 Nov 2025 at 8:02pm |
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
omahagreg
Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2808 |
Posted: 16 Nov 2025 at 9:45pm |
Check out Wild West Farmer on YouTube! They run 3 JD strippers that are 25 years old, still use boll buggies and module builders! Says it is way to expensive to get a new one that puts out bales!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54642 |
Posted: 17 Nov 2025 at 4:52am |
All of those old stripper teeth also have other uses, too...
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4792 |
Posted: 17 Nov 2025 at 10:21am |
There might even be one of those tree stands hiding here somewhere. But I believe that is picker spindle. Or do strippers use spindles too? Since picture of Creston's machines here is as close as I have been.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8458 |
Posted: 3 hours 46 minutes ago at 11:56pm |
Here are a couple clips from the show. It wasn't much, but we had fun! About 150 combined guests from both days. We had guests from Arizona, New Mexico, Texas, Oklahoma, Nebraska, North Dakota, Minnesota, Wisconsin, Illinois, Iowa, Indiana, Ohio, and Ontario. Everyone insisted I need to do this again next year, so that's currently the plan. Going to plan on November 13th & 14th, 2026.
A short clip of field demos and the kids' cotton picking contest: This one is a walk-through history of the models of cotton strippers Allis produced: |
Page <12 |
