Allis Chambers All crop 60 combine wheel hu |
Allis 1952 ![]() Bronze Level ![]() ![]() Joined: 31 Mar 2025 Location: Racine Ohio Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Mar 2025 at 6:22pm |
Would anyone have a Allis Chambers all crop 60 wheel hub dust bushing cover
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1405 |
Is that the same as an Allis Chalmers all crop 60???
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8580 |
This what your looking for ![]() |
Mine is round and a little flatter I tried to copy the picture but it won’t let me my hub is all crop 60 of a pull type combine
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 84932 |
does it pilot into a bore like a trailer grease cap, or bolt on like the above photo ?
It bolts 4 bolts like the orange one but mine is round and a little flatter
And the grease fitting lines up with a hole in the hub that grease the bushings in the hub the hub has brass bushings no bearings
I tried to put my picture on here of the cover of the hub but this forum says it’s to big
Most cameras take 4000 x 3000 pixel photos or bigger... Open the picture in PAINT or other program on your computer and RESIZE to 800 x 600 ..... if your using a phone i think you can e-mail the photo to yourself, and then RESIZE..
What is your email address I will send the pic to you
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5821 |
Robert Is yours like this one in the attached Video ? L/H Wheel at 2:55 minute Mark for L/H wheel, no sprocket R/H wheel at 5:48 with Reel Drive sprocket https://www.youtube.com/watch?v=KinOqKfCuno ............................................................ Hey Stevie Do you really think he could make one of your suggested Dexter Trailer Hub Caps work? |
My cap is flatter and and the grease fitting is in a different position because it Carries grease all the way through the hub question did the 66 have bearings or bushings for the the axle in the hub
That hub looks like hub I don’t need the gear really need the other wheel cover
That hub looks like hub I don’t need the gear really need the other wheel cover So Robert, when you say "that hub" are you referring to the L/H Hub in the Video? G |
Parts book lists different ones per your serial number.
I don’t know the serial number it’s long gone
You can email pictures to
Michaelzakens@gmail.com
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 834 |
Maybe this site might help…
https://allcropharvester.com/ |
dkattau ![]() Silver Level ![]() Joined: 20 Mar 2011 Location: Nebraska Points: 268 |
What’s your serial number? It’s stamped into the frame below the LH cylinder bearing.
Edited by dkattau - Yesterday at 2:36am |
Pictures of what he has.
Someone must have done a farmer fix sometime in its life. Correct me if I’m wrong but this isn’t allis right.
It was a all crop allis Dad bought 2 back in the 70s one good one and one for parts but it’s all Allis Chambers the diagram you sent me is what it had on it but over the years the cap was took off and don’t know where it went
