Allis Chalmers WD Timing
cowwbboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowwbboy Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers WD Timing
    Posted: 13 Feb 2011 at 8:53pm
How do you set the ignition timing on a 1949 WD.
paul s. mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paul s. mn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 9:27pm
magneto or battery ing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowwbboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 9:42pm
Battery
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 12:20pm
Go to our website www.sandylakeimp.com and click on Bills Tidbits under the service heading. The marks are explained under Magneto Timing. Points should spark just as the Center mark lines up with the housing rib. Or use a timing light & turn the distributor so the Fire mark lines up with the rib when running over 1/2 throttle.   Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
FIND US ON FACEBOOK
