Allis chalmers wc |
Ttague39B
Joined: 09 Aug 2025 Location: Tunkhannock PA Points: 44 |
Topic: Allis chalmers wcPosted: 01 Dec 2025 at 7:18pm |
Hi all, I recently bought a 1937 WC, I also have a 39 B and I know that that should have a grill curtain instead of louvers, and I was curious if its the same for the WC, I am gonna get a curtain monogrammed up for the B and wanted to know if I should get two. Thank you
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 569 |
Posted: 02 Dec 2025 at 9:03am |
Someone else will jump in. If this is an unstyled WC, there was a grill available to protect the radiator. It had a diamond shaped pattern with a good frame as I recall and don't know if it was an option or standard equip. Good luck with your new find, those were pretty rugged in their day.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2578 |
Posted: 03 Dec 2025 at 5:43am |
Unless your B is SN101 or lower, it should use shutters and not a curtain. The unstyled WC did use a canvas curtain. AaronSEIA
Ttague39B
Posted: 03 Dec 2025 at 2:47pm |
SN 101 for a b? My serial is 32959, there's no electrical system. Hand crank only, and from what we can tell, from factory on steel. and it has no hole in the grill for louvers nor louvers on the radiator. But it does have the 4 hole on each corner of the grill.
Edited by Ttague39B - 03 Dec 2025 at 2:48pm |
AaronSEIA
Posted: 04 Dec 2025 at 5:40am |
Per the parts book, only the first 101 B's used a canvas instead of shutters. AaronSEIA
