Allis chalmers wc
Ttague39B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers wc
    Posted: 01 Dec 2025 at 7:18pm
Hi all, I recently bought a 1937 WC, I also have a 39 B and I know that that should have a grill curtain instead of louvers, and I was curious if its the same for the WC, I am gonna get a curtain monogrammed up for the B and wanted to know if I should get two. Thank you
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 9:03am
Someone else will jump in.  If this is an unstyled WC, there was a grill available to protect the radiator.  It had a diamond shaped pattern with a good frame as I recall and don't know if it was an option or standard equip.  Good luck with your new find, those were pretty rugged in their day.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 5:43am
Unless your B is SN101 or lower, it should use shutters and not a curtain.  The unstyled WC did use a canvas curtain.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 2:47pm
SN 101 for a b? My serial is 32959, there's no electrical system. Hand crank only, and from what we can tell, from factory on steel. and it has no hole in the grill for louvers nor louvers on the radiator. But it does have the 4 hole on each corner of the grill.
Edited by Ttague39B - 03 Dec 2025 at 2:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2025 at 5:40am
Per the parts book, only the first 101 B's used a canvas instead of shutters.
AaronSEIA
