Allis Chalmers Square Balers |
shattercane
Joined: 23 Jul 2011 Location: Aurora, KS Points: 305 |
Topic: Allis Chalmers Square BalersPosted: 02 Aug 2012 at 7:23am |
I was wondering if anyone out there would be able to do a brief rundown of the Allis Chalmers square baler history...for example I have heard that the 302 only had two u-joints in the pto shaft which caused time consuming turns so they went to a three u-joint shaft and called it the 303...that's all I've heard and all I claim to know. I am trying to figure out which ones were twine tie and which were wire so I can start looking for "the one." Thanks,
Travis
29 L Case, 37 CC Case,40 A-C allcrop 40, 43 B Allis Chalmers, 50 DC Case, 54 WD-45 WF, 67 190 Gas
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1034 |
Posted: 02 Aug 2012 at 1:08pm |
I am pretty sure that most if not all models were available in twine or wire versions,so model # will not tell you if it is twine or wire. The 443 and 444 were the last models built. 443 has short tongue (2 joint pto) and 444 has long tongue (3 joint pto). 444 also has a better pick-up. It has teeth spaced closer together (similar to NH super sweep) and I think it has one more row of teeth than the 443. I'm pretty sure plunger speed is same on both. Options were the same on both and included pick-up gauge wheel,toolbox,wagon hitch with bale chute. I own a 444 and bale only 6-800 bales a year and it works great. Knotters are same as NH. In fact mine has a complete NH knotter on one side. Not a real high capacity baler,but probally keep up with most balers back in their day.
shattercane
Posted: 02 Aug 2012 at 10:36pm |
Thanks for the info, I was hoping they would have changed numbers if it were wire, but I'm sure they had their reasons so I won't hold it against them. I truly appreciate the information. At least now I know that if I ever see one on auction or listed there is a chance it could be wire tie.
Thanks again!
HagerAC
Posted: 02 Aug 2012 at 11:16pm |
We have a very well used 303, excellent baler for its age. Even with the smaller pick up on it than the 400 series balers I think it has excellent capacity. Back when it was new my dad used to work for the original owner of the baler, and they would bale 3 loads an hour, or around 350 bales an hour.
Ricky D
Joined: 13 Sep 2009 Location: Waterloo ON Can Points: 57 |
Posted: 05 Aug 2012 at 7:29pm |
We have a 443 with a 3 jount PTO< works great (now), had local NH dealer go over knotters, now it ties every time. are you looking for wire or twine tie?
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 05 Aug 2012 at 8:49pm |
The 303 had one extra bar in the pickup, so it picked up grassy hay cleaner. It also had more retarders in the chamber to make tighter bales over the 302. I have a 302 that we used to use at the AC Jamboree, and it worked very good.
Mikeybob
Posted: 22 Jul 2013 at 9:36pm |
I just got an AllisChalmer 303 square baler and am having trouble installing the string. I am new to the baling thing and need help. Hope it is easier than I am making it. I am also new to the sight so if I am posting in the wrong place sorry.
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4948 |
Posted: 22 Jul 2013 at 9:47pm |
First off welcome to the site.A lot of knowledge on here.Correct place to post, would probably get more responses to a new post. "Need Help with baler" . Wish I could help but I am sure some one on here knows how to string that baler.Only advice I can give is find a manual.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Flint23
Joined: 31 Jan 2011 Location: New Haven In Points: 429 |
Posted: 23 Jul 2013 at 2:31am |
I just finished baling around 1000 straw bales with my 302 and tied all but 6 of them. Three because the knot where you tie the strings together got hung-up in the string tensioner. I was quit happy this year because this was the best the baler has tied since I got it, lots of tweaking.
been there done that, not doing it again...
Lonn
Posted: 23 Jul 2013 at 5:46am |
If it's like the New Holland 270 you run the twine through the little tensioner first then following and through the glass guides and the through the ends of the needles located underneath. Then tie each twin off somewhere straight rearward of the needles. If you tie them to the side you may break a needle. The baler should do the rest.
Wink I am a Russian Bot |
Posted: 23 Jul 2013 at 7:05am |
As far as I'm concerned, the 302 and 303 were made at the same time in history. You either bought the short tongue 302 (less $$$$$ to purchase) or the long tongue 303 (more money) and either one was wire or twine tie. |
Mikeybob
Posted: 23 Jul 2013 at 7:10am |
I will give it a try tonight. Thank you for the response.
GENO
Posted: 21 Jun 2017 at 6:54am |
We just replaced the "blll hooks" on my 302 baler. The NH part # 796734 worked fine. They only required a small alteration to the gear as the hole for the "lock pin" was a little different from the original Allis. Hope this helps.
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2075 |
Posted: 21 Jun 2017 at 1:30pm |
Most of the knotter parts are interchangeable between AC and NH. Parts are also still available from AGCO as well.
Thanks & God Bless
Dennis |
