Allis chalmers snap coupler
toddkatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddkatz Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers snap coupler
    Posted: 01 Sep 2018 at 8:32am
I was just giving a 6ft scraper blade for my D15. I have rebuilt the snap couplers on my tractor side but the scraper just has a bolt through the hole. How do I find the implement side of snap coupler that bolted to the scraper blade. Does someone have a part number or close up picture how it came from factory? Hoping to find originals and bolt to scraper blade.
albrown915 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albrown915 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 8:59am
Better able to help you if you could post some pictures
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 9:29am
Is it similar to this one I took a pic of at GOTO yesterday?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddkatz Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 11:06am
Pretty sure there is something mounted where the bolt is that slides into coupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddkatz Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 11:07am
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 4:32pm
That is an aftermarket blade, not A-C. It probably bolted through the hole in the end of the lift arm without using a snap coupler latch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddkatz Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 4:58pm
Ok thanks just trying to be safe don't want it flipping over on top of me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 6:02pm
FYI, Todd, the genuine AC blade is easy to ID, it has like a 5/8" or maybe 3/4" moldboard thickness, VERY heavy...
The bolts, on yours, look a little short, for the job. They should go all the way across both ears of the lift arm clamp, or you will end up breaking one ear, off of one side, or worse, both...
Edited by DiyDave - 01 Sep 2018 at 6:10pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 6:12pm
Todd have you replaced the double C spring inside the snap coupler bell? It should be done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 6:24pm
The Snap Couple is the connection on the bell, under the middle of the tractor. The lift latches are mounted on the lift arms and connect to the implement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 9:28pm
I have an aftermarket SC blade and that's basically how it hooks, a couple bolts that hook in the lift arm latches. Originally it just had 2 separate arms like the one in the pic. I found that using the blade anywhere than parallel with the rear axle the arms would disconnect. I built new arms just like a factory blade has and that fixed the problem.
This page was generated in 0.176 seconds.
