Allis Chalmers Model G Tractor - $1,200 |
JCSinPITTS,PA
Topic: Allis Chalmers Model G Tractor - $1,200Posted: 29 Aug 2022 at 11:09am |
It has been sitting in a shed since 1998 and quite possible
longer than that! Unknown history before that Look at the pictures in order and read the text I wired brushed serial number (G23960) and installed new
shifter boot since it will be outside for photos and it been raining every day. All items are there, it’s a complete tractor. Thieving cousin stole some parts but I have purchased
replacements and will be included in the sale. Has Master Toolbar & Master Lift with all parts and it
works Has snowplow or manure scraper Has decent tires on back and mismatched fronts – all hold
air Thieving cousin stole seat pan & seat spring – I have
purchased a replacement seat spring – you will need to find a seat pan. Starter & generator are there Here is the BAD part, it looks like something was bolted to
clutch housing and broke a chunk out, I am in the process of bidding on a
replacement clutch housing and whatever I pay will be what you pay, IT WILL
NOT BE INCLUDED IN THE SALE, it will be an extra cost item, if you want it. Missing hand crank & hand crank casting – these are
being reproduced Carburetor is there and distributor – thieving cousin stole
air cleaner tube but I purchased another one and will be included with the
sale. Intake/exhaust manifold is rusted thru and at some point
someone tried to patch – these are being reproduced I didn’t try to start because of manifold issue, that will
be for new owner, but the motor turns over because while being towed I put into
gear but the transmission lube leaked out because of missing PTO cover so I
quit. Thieving cousin stole either the PTO or the plate that
covers the hole – you will need to decide what you want to do there – I don’t
have a PTO or the plate. Radiator looks like crap but has had water it there
for over 2 weeks and hasn’t went down. Missing taillight – these are being reproduced So that it, basically a complete tractor that needs some
loving! Edited by JCSinPITTS,PA - 29 Aug 2022 at 11:18am |
Les Kerf
Posted: 29 Aug 2022 at 7:45pm |
I sure wish you were closer
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 29 Aug 2022 at 7:56pm |
Hmmm...... that's interesting. A trailer ball mounted up front. Musta' been used for moving trailers, boats or sometihin' around....Great resto project for someone. Steve@B&B
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11411 |
Posted: 30 Aug 2022 at 2:10pm |
Yes, Steve I noticed that ball, different.
Joined: 11 Sep 2009 Location: illinois Points: 90845 |
Posted: 30 Aug 2022 at 8:28pm |
