Allis Chalmers K
gvoerm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gvoerm Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers K
    Posted: 19 Nov 2013 at 11:40am
Does anyone have a bronze throwout bearing/collar for the hand actuated Main clutch on an allis chalmers K? Or know of a source for these? If not is there interest if they are reproduced?
Grant
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2013 at 1:05pm
I think power units with the same motor have that through out bearing or try Norm Meinert he may be able to help clutch must have been disengaged and running for a long time to wear it out.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2013 at 4:21pm
Parts should be available.  It is most likely either a Twin Disc or Rockford Clutch.  Some Rockford clutch parts are difficult to find.  But it would be same as industrial clutch used on many OEM power units (most likely).
Need more information.  Flat flywheel?  Bolt circle of the drive ring?  Is there a plate with clutch information on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 1:36am
No drive ring on K crawlers clutch is mounted on to first motion shaft with teeth around the out side of the plate that engage  the toothed flywheel.Drive plate is semi floating untill clutch is engaged to clamp it up.It is clamped between two heavy cast iron plates.
Edited by everett048 - 20 Nov 2013 at 1:39am
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 10:17pm
I have one for the k. the power unit is different size. call 815-865-5372
Norm
This page was generated in 0.368 seconds.
