Allis Chalmers HD4
madtrapper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madtrapper Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers HD4
    Posted: 27 Jun 2022 at 9:09am
Dozer works fine when cold but when it warms up, gets hot, it looses power.
I let it cool down and it will move again.
Any help please.
Edited by madtrapper - 27 Jun 2022 at 9:10am
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 12:38pm
Is that in both directions ? Sounds like clutch pack problems of slipping - internal leakage or worn clutch pack with low hyd pressure .
Post Options Post Options   Thanks (0) Thanks(0)   Quote madtrapper Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 12:58pm
Total lack of power.  Dozer doesn't have enough power to turn the tracks but if you leave it sit for a while and cool down it works again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 10:36am
Is that in all 3 gears ? Seen one where they were running in 3rd and complained no power after a bit - overheating from slipping .
Post Options Post Options   Thanks (0) Thanks(0)   Quote madtrapper Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2022 at 12:51pm
It does it in all gears.  Works perfect until it warms up and then looses all power
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 3:31pm
Need to check pressure and for leakage , from front pump , torque converter and leaking or worn clutch pack - low hyd pressure to clutches
