allis chalmers hd 16 ac torque converter seal
lunchbox06 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lunchbox06 Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers hd 16 ac torque converter seal
    Posted: 07 Apr 2020 at 10:36pm
i have a hd 16 ac serial number 1068 and im pouring fuel out of my torque converter.  anyone know how to change that seal? do i have to pull the whole converter or can i just take the rear plate off to get to the seal.  also does anyone know where i might be able to find the part to replace the seal.  i have the part number if it helps just let me know.  any help would be great thanks.
Edited by lunchbox06 - 07 Apr 2020 at 10:37pm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 7:14am
go to http://minnpar.com and put in your seal #.
you can also try the oem seal makers.
the first link is for AC parts supplier.
the second 2 are SKF and National seals cross #  and most AC numbers will cross on 1 or the other.  if it doesnt come up with these 3, you will have to try to match up by dimensions.  I have had pretty good luck coming up with seals and bearings this way even back to 1937 UC tractor.
EDIT>  just looked at my HD20 parts book and the output seal is a multipiece job.. soo this route may not work if its the same on a 16 unless minnpar happens to have the KIT.
Edited by CAL(KS) - 08 Apr 2020 at 7:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote lunchbox06 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 8:21am
Do you know if to change that I'm going to have to put the whole converter to change it or can I just pull the back cover plate and change it that way. Also would the front seal and real seal be the same or different?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 9:37am
i have no idea.  my 16 is direct drive and HD20 is new to me.  hopefully never have to mess with a converter.
This page was generated in 0.115 seconds.
