Allis Chalmers FP40 24 fork lift
Mike Price View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Price Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers FP40 24 fork lift
    Posted: 22 Nov 2022 at 9:51pm
I have an Allis Chalmers FP40 24  fork lift. Starts and runs fine but just today the forks will not lift or tilt. Hydraulic tank is half full. Fluid looks clean no sign of water contamination. No fluid sound changes when either of the levers are moved in either direction. No visible signs of busted hose. I just used it last week to remove a pickup truck bed..today it starts and runs good but won’t lift or tilt. It does sit out in the weather rain or shine. Is there a by pass valve somewhere that allows the fluid to continue to circulate when the cylinders are not moving? I’m wondering if it has a bypass valve that might be stuck open. Any help is greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 10:06pm
normally the bypass would be inside the valve.. Pump will pump thru the valve and back to the tank until a spool is pulled and that closes off the bypass and sends to oil to the cylinder........ you might loosen the SUPPLY hose from the pump into the valve and see if you have pressure..
Could the inline filter be plugged or frozen ?  could the coupler on the pump have broken and pump dont turn ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2022 at 4:33am
X2 on the pump coupler. you need to look at the pump, the first question is is it turning?Wink
