Unofficial Allis Homepage
Allis Chalmers EB Has No Power
Valiant Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valiant Farmer Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers EB Has No Power
    Posted: 14 Dec 2019 at 3:24am
Hi all,
My Brother and I have been fixing up my Allis Chalmers EB.
We have reset the timing, it sounds better but it has little to no power.
It can just start off in 1st gear but it dies soon after.
What should I do now?
We don't know much about magneto ignition.
We would be grateful for any help!
Thanks!
Samuel
Edited by Valiant Farmer - 14 Dec 2019 at 3:24am
PSALM 119:105 : Thy word is a lamp unto my feet, and a light unto my path.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2019 at 7:15am
Sam,
I would recheck the fuel flow/ carb.
Could be more than one fouled plug??
Good news is it runs, so it is probably a minor issue.
Edited by Sugarmaker - 14 Dec 2019 at 7:16am
D17 1958 (NFE), WD45 1954 (NFE), WD 1952 (NFE), WD 1950 (WFE), Ford Jubilee, IH TD6 Many IH Cub Cadets
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2019 at 9:30am
Did it have good power before you started fixing it up? If it did then I would consider undoing what has been done. If not then I would proceed as Chris has suggested.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2019 at 9:32am
Did you check compression? Change plugs and wires? Check that the plug wires are in the right order?
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2019 at 9:58am
Can you rev her up. If so, does she still do the same when revved up.
