Allis chalmers D17 Serial number
Corbincdc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers D17 Serial number
    Posted: 12 Jul 2010 at 4:23pm
I just bought a D17 and cant seem to find the serial number.  I have looked on the left front torque housing. Nothing.  Is there any where else I could look.  I want to find out it's year.
Thanks
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 5:35pm
Try scrapin the paint off the torque housing where it should be.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 8:10pm
If there is no serial number where it is supposed to be, it could have a replacement torque tube. The dealer was supposed to restamp the serial number but not everyone did. Post some pictures and I'm sure we can get the year very close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 8:12pm
the problem is I dont think the tractor has torque housing?  Is this a critical housing component?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 8:17pm
I'll Post some picture in the morning
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 8:21pm
Some people might think of that particular area of the torque housing as the flywheel housing. Your tractor definitely has has a torque housing!!
Try this site for the exact location where your number should be found.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 11:05pm
Thank you I'm new to this.  Yes i confused the torque housing with the  side panel. thanks will look and see in the morning.
NEMOSoyBeanBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEMOSoyBeanBoy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 12:24am
If you want to find the year..The block could still have a date in the side of it. If you get lucky and its the original engine..that would be your year. If Its a diesel..i believe its on the rh upper center of the block. Kinda under the intake. Someone please correct me if im wrong. Gas..I really cant remember! .
-NEMO Soy Bean Boy-
       -Kevin M.-
It isn't what you buy,
   Its what you build.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 12:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 12:15pm
Thanks for the replies.  I scraped off the dirt in that location but no  number.  There are a couple of numbers on the lift arms  4454-b. pictures
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 12:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 12:37pm
Your D-17 is a 1957,58,or early 1959. The serial number is just below the air cleaner on the torque tube where the engine bolts up and the side frame bolts in. There should be a flat spot on the slope part. You may have to clean it real good because the number is stamped in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 3:45pm
Look at the picture Claus posted. You can clearly see the front frame rails are bolted to the torque tube, or torque housing and you can see the numbers stamped in the housing flange. If yours doesn't have numbers stamped there it must have a replacement housing. If you can find the engine number, maybe somebody could compare it to theirs and get you close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 4:00pm
Corbin, see where your fuel line crosses over where the back of the engine and the next big casting (torque housing) is? Looks like close to the end of your rubber hose where it is clamped on to a metal tube going to the carb. Compare that area to Claus's pic. If it has a serial #, that's where it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 4:00pm
Just for the record the photo I posted was taken of my 170, the 170 numbers and the D17's are in the same place.
This page was generated in 0.083 seconds.
