Allis Chalmers D15 |
powertech84
Joined: 17 Oct 2009 Location: Wisconsin Points: 487 |
Topic: Allis Chalmers D15Posted: 27 Apr 2024 at 10:05pm |
I'm considering selling my series 1 D15. It has a narrow front, gas engine, power steering and snap coupler hitch. It starts and runs good. Rear tires don't have much tread but otherwise are OK. One rear rim has rust around the valve stem. I have a good used rim that will go along with the tractor. I also have a mismatched set of rear tires with excellent tread.The power director seems to shift normally. Rear hitch lifts like it should. It appears to have been repainted at some time. All the sheet metal including the fenders are in very good condition. I'm located near Watertown WI. I can deliver within reason for the right deal. I'm asking $2650. Video is at https://youtu.be/whFUFI1fwMc?si=2zIYiH5KXRpPzvtP
Pictures also available if you want to see something more specific. Edited by powertech84 - 27 Apr 2024 at 10:11pm |
powertech84
Posted: 27 Apr 2024 at 10:10pm |
A few more notes. The wheel with the bad rim has fluid in it. The other does not. I will be having the fluid removed and the rim swapped as time allows between planting, working and family time. It's currently running on my carb from my h3 dozer. The original carb is apart on my workbench right now, and it's hopefully going to be my Sunday project, so it will have a freshly rebuilt carb, using a premium rebuild kit installed. Any other questions please just ask.
housemover
Joined: 01 May 2012 Location: Belleville, Ks Points: 103 |
Posted: 07 May 2024 at 6:18am |
Is your D15 I still available? My email is leon@ballandson.com or call 785-527-3200 Thanks
housemover
Posted: 07 May 2024 at 6:21am |
Sorry, Forgot to ask if it jumps out of any gears or uses any oil.
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3253 |
Posted: 07 May 2024 at 7:26am |
Looks like a series 2 to me. Just saying.
powertech84
Posted: 07 May 2024 at 7:39am |
Yes, I still have it. It's definitely a series 1. It is serial number 1926, which would make it a very early 1961, the second year of production. It does not jump out of any gears, and it does not appear to use any oil, however I can't say I've put a ton of hours on the engine myself.
powertech84
Posted: 19 Jun 2024 at 8:09am |
I still have this tractor for sale. I did get the rear rim changed out, so the tractor is completely ready for use.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 19 Jun 2024 at 10:56am |
Air cleaner on the left: Absolutely positively a series I
