Allis Chalmers D15 Series II Power Steering Hose
daxlw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daxlw Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D15 Series II Power Steering Hose
    Posted: 06 Jun 2024 at 8:16am
Anyone know where or how to fix the high pressure side of the power steering hose?  Developed a crack in mine and its been a trying time to find a replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2024 at 11:11am
We had to have a local hydraulic shop repair ours.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2024 at 3:53pm
Have you tried AGCO?
Post Options Post Options   Thanks (0) Thanks(0)   Quote daxlw Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 8:27am
Ive checked with AW, Stiner, Inline, and AGCO, but they dont have any. Part #70233483.  May have to use compression fittings or find used somewhere.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 9:05am
I would take it off and send it to "INLINE TUBE" to have it copied. I'm sure that they don't have in ready to go or even in their listings. I had a local shop make some for me a few years ago, although it did fit at each end, it looked nothing like the original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 9:22am
Dax,
I sent you a PM.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 9:23am
Your local NAPA store might make hoses.. take the original to COPY.
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 9:23am
I’ve had decent luck brazing steel tubes, if it’s just a small crack or area needing repaired. Not sure how heavy-walled the p/s tubes are, but the hydraulic lines are substantial and easy to braze
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 4:16pm
They are NLA so that’s why we had to have ours repaired. Normally we would just order one from SLI and know that it’s OEM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 4:54pm
I don’t have it ether.
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 9:29pm
Hydraulic Solutions    Sheldon, Iowa  take the old one to them:
you will be impressed what they can do!
Post Options Post Options   Thanks (0) Thanks(0)   Quote daxlw Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 7:31am
For a quick fix, I bought a 50 inch 3/8th brake line from AutoZone and bent it to specs.  Ideally, you would want to get a 40 inch line, it would fit easier but I did not have that option.  The ends were the same size as the old line.  It does the job for now.  If this did not work, I would have cut out a section of the line and used compression fittings to make the old ends work or shorten the new breakline.
This page was generated in 0.057 seconds.
