Allis Chalmers D crankshaft
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D crankshaft
    Posted: 12 Jul 2015 at 9:03am
I posted earlier looking for a Model D, WD-45 powered  crankshaft. The tractor and grader crankshafts are different as the grader shaft does not use the single hole for the single puley mount, but uses a triple pulley and requires a Woodruff key and the end of the shaft drilled and tapped to 5/8-18 NF thread. Our shaft is cracked at the #1 crankshaft throw radius. AC part number is 70230003. Please advise if you have a crankshaft. The old number from the book is a226532 and the casting number on the shaft is 226535.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
rmcghie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmcghie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2015 at 11:02am
took motor out shaft would have yo be ground as it is still in motor and had water init
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2015 at 3:07pm
I was contacted by a gentleman from Missouri in July. He had a crankshaft and also arranged delivery to me. It has been re-ground and  is ready to bo back into the grader.
Thanks for the note.
Curt Anderson
