Allis Chalmers C Thread size adaptors
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers C Thread size adaptors
    Posted: 14 Jul 2024 at 8:26am
Hi
I am looking for the thread size for adaptor on the Allis C hydraulic.
 Pump out , Ram in , Pipe , Control valve left right
Edited by John426 - 14 Jul 2024 at 8:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2024 at 9:46am
Ii think most of the hydraulic fittins are a 1/4 inch PIPE thread..  Noramlly the hose is 1/4 inch male pipe and the fitting in the valve / cylinder has a 1/4 inch swivel pipe fitting.
the second photo you posted says HOSE, but looks like a TUBE ???  The Allis C only used 1/4 inch PIPE and hose fittings.
Edited by steve(ill) - 14 Jul 2024 at 9:58am
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2024 at 9:49am
most systems i have seen use this fitting that screwes into the valve/ cylinder, and has a swivel to screw to the hose... all 1/4 inch pipe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2024 at 9:54am
Here on this side of the water, 1/4" NPT (National Pipe Taper) Is easy to find. In France you may have to go to some industrial Hydraulic place to get what you need to do what you want.
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2024 at 6:41pm
< id="idg-io-safe-browsing-enabled" ="" oninit="true">
Thanks!  Forgot that I need two of these!!!
This page was generated in 0.089 seconds.
