Allis chalmers big10 no fire
Ticard76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ticard76 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers big10 no fire
    Posted: 24 Sep 2017 at 2:37pm
Im getting very little fire thru the plug wire its a dull yellow spark and doesnt give any jolt maybe once out of 100 tries to start. It seema to me that I'd have to take the engine out to get to the points or whatever. Ive heard of a method of putting a battery type system on there to bypass the ild stuff. Has anyone ever done this? My little tractor runs great and i love it really would like some advice on this. Im not much of a mechanic thanks in advance
rustydollar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustydollar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 8:51am
Yellow spark usually indicates a bad condenser.
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 4:45am
No need to remove engine. Points are on left side of engine under a rectangular cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ticard76 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 5:39am
If i follow the plug wire it leads to inside tje engine.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 8:17am
The coil is mounted above the flywheel but the points are external. Check those first, probably just need to be cleaned.
This page was generated in 0.101 seconds.
