Allis Chalmers B-110 bevel gearsO
NorthernChill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthernChill Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B-110 bevel gearsO
    Posted: 17 Aug 2021 at 10:42am
Finally got my old Allis B-110 going(new coil) and I noticed a weird sound coming from the solid drive shaft. Couldn’t find anything wrong after looking so I kept mowing…. Well the noise went away but the tractor stopped moving no forward no reverse. I looked it over and found the issue in the bevel box housing. I pulled the back plate and sure enough the gears were ground(metal filings in box). Where can I get new gears? Can I put different gears in? Any interchangeable gears from other Allis or Simplicity garden tractors? I’m having a hard time finding bevel gears for this.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2021 at 8:21pm
It would probably be easier to swap a complete box into it from a donor machine. The box would have to be from a pre '71 tractor, "Foot dragger" with a 3 speed or hydro, the variable drive tractors have a longer cross shaft which is not compatible. The gears themselves are the same from the Simplicity 700/AC B-1 up to the B-200 Series and Simplicity 3200 series. The most common problem I find in these boxes is worn keys, and the input gear wears at the keyway and where it fits onto the input shaft. The input shaft also wears.
This page was generated in 0.099 seconds.
