Allis Chalmers B only Runs On Two Cylinders |
SS_Skippy ![]() Bronze Level ![]() Joined: 21 Aug 2012 Location: PA Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Aug 2012 at 12:10pm |
Hello I am new to this site and this problem has me stumped. My uncle brought up a B for me to work on and I got it to run by cleaning and rebuilding the carb. When it was running it did not sound quite right so when it was running I took off each plug wire one at a time starting at the radiator. The one closet to the radiator is firing and so is the one closest to the drivers seat. The two in the middle will not fire. Those two both have spark, and are both getting fuel. I also cleaned up the points and set the timing. Any ideas? (This tractor has the magneto and is electric start.) THANKS
Redwood ![]() Orange Level ![]() Joined: 16 Jan 2012 Location: Ontario Points: 631 |
To hit the easy to eliminate suggestions did you recheck the firing order and spark plug firing gaps?
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
You probably have the two wires interchanged. Remember the firing order is 1243.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Easiest thing to check first is to switch the wires on 2 and 3 around.
Kip-Utah ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Southern Utah Points: 917 |
Paint it Green & tell everyone it's a JD B!! |
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
I crossed the wires on one of my "first" service calls. Fortunately, the master was at hand and corrected it quickly.
Can't have my favorite not running right. Welcome to the forum. Let us know how it goes. Good Luck! Bill Long |
At first I did have the wires in the "correct" order on the cap and plugs, then I went out and started switching wires around and got it to fire on all four cylinders. Don't ask what I did because it is not in the correct order. I am going to get some new plugs and wires but right now it sounds pretty good. Thanks for all the help.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Richard ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: Springfield, IL Points: 198 |
I once worked on my WD-45 when it wasn't running on all 4 cylinders. I 1st checked to make sure the plugs were firing but I did it with the plugs out so I could watch for spark - they all fired. And they all looked good. After replacing the points, condenser, rotor, distributor cap, plug wires, I finally replaced the spark plugs. Engine ran fine after that. A mechanic later told me the plugs were not firing under pressure.
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
Perhaps the head gasket is blown between 2 & 3 cylinders.
I had a 149 cu in that didn't sound right. If I pulled the plug wire off #1 you could hear it miss. When I pulled the wires off #2 or #3 nothing would change. When I pulled #4 you could here it miss. Then I pulled the wires off #2 & # 3 at the same time then both would miss. I then pulled the head and the new head gasket had blown between #2 & #3. Dusty
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6081 |
The Allis four-cylinder engines have a firing order which is somewhat opposite of most of the world... and it's not always apparent which towers on the cap of a magneto go to which plugs... because some moron (like me) would, rather than take the time to remove the cap and rotate the rotor to the proper plug, just slap it on, figure out which one matched which cylinder, and let 'er rip... and leave the next guy to figure out what happened.
But no matter- they'll work regardless... just so that they fire in the right ORDER. Obviously, since you swapped the wires, and it came to life, the problem was that firing order was switched. Perhaps it's because the rotor was assumed to turn in one direction, rather than the other... and with mags, that's not unusual. Anyway... I went through this routine with a great big Hercules JXLD... 331ci inline six, the engine's oilpan holds 37 quarts, and the radiator is 38" wide and 45" tall... and has a 24v starting motor, which I decided not to use, because it had a perfectly good hand crank... But I had a situation where the magneto decided to go on strike. It was due for a rehab, so I took it in to my hero John Boyens, who gave it a meticulous work-over... and I finally got it reinstalled on the big Herkey... totally ignored the rotor position, because no matter WHERE you look on this monster, the firing order is NOT indicated... instead, I just took out all the plugs, left 'em hooked to wires, and set 'em on the head. Put one plug in #1, and turned the crank 'till I had compression... then slowly went past the CLACK, and look-see'd which one sparked. Then I swapped wires so that one landed on 1. Then moved my plug to #2, repeated... then 3, repeated, then 4,5,and 6. Put in all plugs, turned on the fuel, gave it a snort of ether (it'd been a while, and stepped on the crank through three clacks, and it started right up. I love magnetos... never hafta worry about a dead battery... |
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
had that happen on a b after getting the mag.overhauled.the slot on the impulse was straight up and down.some one had jake rigged the mag drive gear.retimed it ,ran ok
The way mine is set up is number 1 post on the cap actually goes to cylinder #4 and number 4 goes to cylinder #1. I know on my farmall H that both 1 and 4 are on compression stroke at the same time so maybe this is the same. When I tore apart the magneto I made sure that the gears were matched up. My magneto has the condenser on the right so I put the teeth in the C tooth. Will get some new wires and plugs but I think it sounds pretty good as it is. I can now take off in third if I am careful an at a fast idle. It sounds a lot like this tractor on YouTube. http://www.youtube.com/watch?v=Y-DXSffkA_U
Thanks for all the help I will try and take some pics of it tomorrow. And I am sure I will have more questions. Edited by SS_Skippy - 21 Aug 2012 at 9:12pm |
If it sounds as good as the one in the video, I wouldn't try to fix anything on it
Went to go take pictures and the camera was dead maybe tomorrow, does anyone know what plugs to use in this? Thanks
AC45 or Autolite 295
I get better reports on the auto lite 295. In fact, our electrical expert, SteveNJ suggests Auto Lite only.
Glad to hear my favorite is running well again. Good Luck! Bill Long |
CAdon ![]() Orange Level ![]() ![]() Joined: 14 Mar 2012 Location: southern CA Points: 1019 |
hahaha dontya just love dick l's "thousand words" posting above. he always seems to go straight to the heart of the matter. "here's the answer and that's that!".
thanks dick!
52 CA, 41 B and a little B1 oh, yeah... and an 8N ford snuck in there, too.
Just think... 25 years ago, that'd involve a roll of film, two trips to the photo processing shop, an envelope, a stamp, and about six weeks...
I love it when modern technology can be used to share OLD TECH. I just wish my cellphone had a magneto, rather'n a battery... |
Here are the pics finally, oh yea I forgot it has a front end loader. Needs new cylinders for the bucket. Still haven't gotten the OK to get the new plugs and wires and it will also need a new sediment bowl.
