Allis Chalmers B Mysteriously Quits
JR Maley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Maley Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B Mysteriously Quits
    Posted: 09 Feb 2011 at 1:25pm
My B will suddenly quit even without load.  I rebuilt the carb and replaced the condenser in the Fairbank Morse Magneto.  It has new properly gapped plugs and new gasoline in it.  I have a new sediment bowl which I plan on installing real soon and cleaning the fuel line, and I also plan on going back into the magneto and checking/adjusting the point gap.
Like I said, the tractor will be running perfectly, with no lack of power or anything, no miss, etc, but then it will suddenly quit.  Does anybody else have any other suggestions?  It seemed to me to most likely be a condenser, but the new one didn't fix it.  It seems to happen more frequently after the tractor has been running at a higher RPM for a few minutes.
I have heard that many times new condensers are bad from the start.  The new condenser also seemed real small compared to the old one (new =3/4" long & old was 1.5" long).  Does anybody know the best condenser money can buy for these magnetos?  The one I bought was a NAPA FM200 as suggested by the AGCO dealership.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 1:34pm
Make sure your gas cap is venting properly
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 1:34pm
I would certainly check the things you have mentioned first, but do you have a remote "kill switch" wired to the magneto?  If so, maybe there is a bare spot in the wire that is shorting out and grounding it out.  I know it is kind of simple and obvious, but I thought it was worth mentioning.
Edited by RyanTN - 09 Feb 2011 at 1:56pm
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 1:52pm
As to the condonser check with Steve B&B he is our resident electrical expert.
The above items are very good answers.  One thing I would suggest is to consider the coil.  When a tractor stops a lot of time that is it even when we sold them new..
Can't have my favorate not running right.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 2:02pm
Check your spark immediately after it dies. If you have no spark, you may have a bad coil in the mag. Check gas flow by removing the plug from the bottom of the carb. I had the same problem with my CA after a renter"borrowed" it. It took me weeks to figure it out. He had used a Clorox bottle to add gas to the tractor and the cardboard gasket from the cap was half floating in the tank. It would get over the outlet hole and the tractor would die like you turned the switch off. This might happen 2 minutes or 20 minutes after starting and was never consistent.
jjrosty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjrosty Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 2:05pm
That sounds like a fuel flow problem.  theres enough fuel for slow running & not enough for high RPM.  after setting a few minutes the carb bowl fills & runs perfect... for a few minutes
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 3:55pm
check your wires at the kill switch and make sure they are making conection, i had the same problem CA and it ended up that the key switch was bad, it would start and run fine and then just like that it would shut off. i put a new key switch on and its been fine ever since.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 7:11pm
  Crud in inlet to sediment bowl
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 8:39pm
My experience was a magneto that was OK til it got hot, like under sustained load.  OK when engine was running cool.
Have had a filter after the sediment bowl on B and it would only run a short time until the filter restriction caused float bowl level to drop.   If you suspect fuel line/ filter issues you could run it out of a temporary fuel tank like from an old mower and see if it helps.
This page was generated in 0.103 seconds.
