Allis chalmers b camshaft resistance
Tcfcowboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcfcowboy Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers b camshaft resistance
    Posted: 2 hours 53 minutes ago at 8:03pm
Hello all, I am working on a total restoration of a 38 model B, I installed new Clevite camshaft bearings, and when I put the camshaft back in, it seem to have a bit of resistance, my question is, should the camshaft spin freely, or is it supposed to have some resistance? Thanks.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 17 minutes ago at 8:39pm
Cam drives the oil pump, which adds drag. New bearings are snug on cam with break-in lube. Cam takes ~5' pounds to start turning and then less to continue turning. Cam should have no binding during rotations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 7 minutes ago at 8:49pm
did you swell any driving in? Roll it around some and remove. Look for bright(tight) spots and scrape down.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 44 minutes ago at 10:12pm
With nothing else attached (no oil pump, crankshaft, pushrods, etc.) the camshaft should rotate quite freely. I would use light oil for checking, use assembly lube for startup.
Edited by Les Kerf - 41 minutes ago at 10:15pm
