Allis chalmers b camshaft resistance |
Tcfcowboy
Topic: Allis chalmers b camshaft resistancePosted: 04 Mar 2026 at 8:03pm |
Hello all, I am working on a total restoration of a 38 model B, I installed new Clevite camshaft bearings, and when I put the camshaft back in, it seem to have a bit of resistance, my question is, should the camshaft spin freely, or is it supposed to have some resistance? Thanks.
KMAG
Joined: 26 May 2020 Location: Elizabethtown, Points: 689 |
Posted: 04 Mar 2026 at 8:39pm |
Cam drives the oil pump, which adds drag. New bearings are snug on cam with break-in lube. Cam takes ~5' pounds to start turning and then less to continue turning. Cam should have no binding during rotations.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8973 |
Posted: 04 Mar 2026 at 8:49pm |
did you swell any driving in? Roll it around some and remove. Look for bright(tight) spots and scrape down.
Les Kerf
Posted: 04 Mar 2026 at 10:12pm |
With nothing else attached (no oil pump, crankshaft, pushrods, etc.) the camshaft should rotate quite freely. I would use light oil for checking, use assembly lube for startup.
Edited by Les Kerf - 04 Mar 2026 at 10:15pm |
Tcfcowboy
Posted: 05 Mar 2026 at 6:04am |
It takes probably, 5-10lbs to turn it with nothing attached, But it rotates smoothly once I rotate it. I polished the camshaft journals with a buffer wheel. I’ll see if I can find a high spot.
Posted: 05 Mar 2026 at 6:30am |
Just keep turning it with penetrating oil while pulling it in/out. Use a speed handle or electric drill. Don't buff anything.
Tcfcowboy
Posted: 05 Mar 2026 at 9:41am |
Thanks, will do.
