Allis Chalmers 8010 shifting problems |
   allis in OZ
      Quote   Reply
     Topic: Allis Chalmers 8010 shifting problemsPosted: 10 May 2017 at 7:12am  |
   Hi,
  I am looking at buying a 8010 2 WD with 5 speed High/low range. I had a drive of it today & it didn't want to go into gear when stationary. it was hard to push the shifter & gears ground some as well. it did shift most times OK when moving. the clutch seemed hard & close to fully extended so I don't know if its a clutch, linkage or gearbox issue. has anyone had this experience or know what could be wrong? I really like the tractor but I'm not prepared to spend big dollars on it to get it operational. thanks in anticipation!
      Quote   Reply
     Posted: 10 May 2017 at 7:25am |
   If you are not familiar with the 20-speed Power Director transmission, that could be the problem. The clutch pedal has to be CLEAR DOWN AS FAR AS IT WILL GO for the transmission brake to stop the gears from rotating. The leg effort is somewhat high compared to a power shift  transmission. There is a cable from the clutch pedal down to the clutch valve (behind the batteries)that probably needs to be replaced to reduce this leg effort.
   allis in OZ
      Quote   Reply
     Posted: 10 May 2017 at 9:58pm |
   Thank's for your help!.... I will check this out.
   SteveM C/IL
   Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8681  |
      Quote   Reply
     Posted: 10 May 2017 at 10:37pm |
   ...and,they never behave well at cold first start up.Drive it around for ten minutes and it works better.Also,you can't shift the 5-speed while moving and not clash teeth.
   allis in OZ
      Quote   Reply
     Posted: 11 May 2017 at 7:01am |
   thanks for that advice too.
  do you have to power off & clutch to shift the lever on the steering column from high to low? I really would be great-full for a start off to running explanation on this transmission.  |
      Quote   Reply
     Posted: 11 May 2017 at 7:09am |
   Lever/switch on the steering wheel is ON-THE-GO like a T.A. on a Farmall.  It always returns to LOW whenever the clutch is depressed.
   allis in OZ
      Quote   Reply
     Posted: 11 May 2017 at 7:26am |
   Thanks again,
  I want to buy this tractor for hay baling with a round baler ( not yet purchased) & loading bales on trucks with the F.E.L.  Will this transmission be suitable for the back & forth loader work?
   Tbone95
   Joined: 31 Aug 2012 Location: Michigan Points: 12249  |
      Quote   Reply
     Posted: 11 May 2017 at 7:59am |
 Back and forth loader work....Unless it is smoother operating than the version of this transmission I have in my 7045, I would not like it for loader work. Granted, mine is old, likely not in pristine condition, maybe slightly different feel in an older series tractor, I don't know as I've never driven an 8000 series. But I wouldn't like my 7045 on a loader.  |
   JohnCO
   Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992  |
      Quote   Reply
     Posted: 11 May 2017 at 1:08pm |
   They are ok for a loader but not easy to reverse like newer tractors with reversers on them.  It should do fine with a bit of practice.  I doubt if you would want to load bales all day, every day, would get old real quick!
  Allis Express participant  |
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
