allis chalmers 7g transmission oil type
martimus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote martimus Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers 7g transmission oil type
    Posted: 14 Aug 2025 at 3:25pm
i need to change the torque coverter, transmission clutches oil. allis chalmers track loader 7G. the factory says transmission fluid type c-1 or api ms, we have been using hydraulic oil, that is what the man i bought it from was using i do not use this loader very much but would like to get the correct fluid installed.  so confused as to what we need. most oils and hydraulic fluid does not have any type or api listed on the labels. any body got any idea what i shoud use
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2025 at 4:18pm
You can use SAE OIL
Adrian View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Adrian Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 5:57pm
If C1 fluid is specified SAE 10W gear oil is the alternative as per Allis Chalmers specification.
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 8:16pm
GEAR OIL IS NO GOD  FOR hd7g transmission
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 1:10pm
Your saying hydraulic fluid, I hope your meaning transmission/hydraulic fluid. A better grade of oil for a transmission than the cheapest of the cheap just for hydraulics fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote martimus Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:43am
yes i did use transmission/hydraulic fluid traveler brand tractor supply, only place around here could buy in bulk.
