Allis chalmers 715c backhoe tire size
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers 715c backhoe tire size
    Posted: 08 Feb 2021 at 2:47am
I have a 82 715c with 2 different size rear tires. I'm going to be replacing the tires and was curious if anyone knew what size tire would be the correct size?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 6:07am
Several sizes could be correct.  Here is the page from the parts book showing the options.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 10:15am
18,4 x24 on my 715B - tubeless - put new Armstrong tires on mine but dang things have weather checked - tubeless valve stems started leaking also around seals - need to put tubes in them now
When I tried mounting the new tires could not get them to bead , had to take them back to dealer I bought them from and it took strap around tire along with 3 Chita air blast tanks working at same time as trying to fill them to get bead to pop up to hold air .
Edited by Coke-in-MN - 08 Feb 2021 at 10:19am
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 3:59pm
Ok I think I'll go with 18.4x24 thanks guys.
