Allis Chalmers 715B - Parts
FarmerJoeVT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJoeVT Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 715B - Parts
    Posted: 03 Nov 2014 at 3:40pm
I have a 715B Backhoe/Loader that is shutting off after running for some time. It requires time to cool off before restarting again. I have read that some believe this to be a fuel pump issue. When I called the parts shop they asked me if I was replacing the Lift Pump ($39) or Injection Pump (Rebuilding needed)? Can anyone help me answer this question or have a fix to this problem? Additionally, I have also read that others have experienced dark smoke when initially starting the 715, that goes away after a few minutes of running (as mine does). Some mention a long term solution of replacing the Fuel Injectors, does anyone know where these can be purchased with the other parts I might require to fix the initial problem posed above?
Thank you in advance.
This page was generated in 0.480 seconds.
