Allis Chalmers 710 H |
MiKe04gt
Topic: Allis Chalmers 710 HPosted: 20 Dec 2016 at 8:54pm |
I have an old Lawn tractor that was given to me. I am not sure about much on it. I know it is a 710 H, with a K301 Engine. I got it rebuilt the carb, New points, coil, Rewired it. I now have it running pretty well. However the part that bolts to the flywheel with 4 bolts, then to the drive shaft disk with 2 bolts broke. I don't know what this part is called to try to fine one. It looks like one of the bolts worked loose, then sheared both bolts off inside the part. However when it broke it busted out the threads and now is no good. thanks for any help.
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 20 Dec 2016 at 10:40pm |
Mike:
Might also want to post on Simpletractors.com - between these 2 websites I am sure you will find the help/parts you need. Welcome to a fantastic forum! |
Mikez
Posted: 20 Dec 2016 at 11:22pm |
Should be some spacers bolted through what looks like a white plastic, or fiber looking disc then bolted to the drive shaft. That little disc thing brakes. Do you still have the spacers.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 21 Dec 2016 at 6:35am |
Didn't think they made a 10 HP with Hydrostatic.
Only 712H and 716H Gary http://www.simpletractors.net/models/ac_700_series.htm |
MiKe04gt
Posted: 21 Dec 2016 at 11:37am |
Sorry, In the daylight hours I looked and it is a 712H
MiKe04gt
Posted: 21 Dec 2016 at 2:39pm |
I think it is called a Front drive adapter. I cant figure out how to upload a Picture.
farmtoybuilder
Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
Posted: 21 Dec 2016 at 4:03pm |
An in stock item at most Simplicity dealers! Same disc used on all the L&G tractors. You can double them up for extra strength when pulling. And as Mike said they also have a coupler steel spacers and Heavy flat washers used on them. I've got a new old stock kit #103052 with new bolts, HD washers 1 disc and spacers left for $30.00 plus $8.00 postage
online they want $37.75 plus shipping for them. |
Mikez
Posted: 21 Dec 2016 at 4:20pm |
Can you show me a picture farmtoybuilder we stock them separate. Never seen the kit
MiKe04gt
Posted: 21 Dec 2016 at 5:09pm |
Can you send me a Picture? Mine is a Cast iron piece Engine bolt holes is 4- 3/8" Bolts 3" Across on Center. then the 2 for the Drive shaft is 2- 3/8" bolts 2½" on center. Do you accept PayPal?
MiKe04gt
Posted: 21 Dec 2016 at 5:20pm |
I was able to fine all the spacers and thick washers on each side of the fiberglass disk. But new ones wont hurt either
farmtoybuilder
Posted: 22 Dec 2016 at 7:50am |
The disc is 2 1/2" centers. Yes we accept pay pal. Email us direct at farmtoys@sbcglobal.net I'll try posting a picture. You can purchase just the disc from dealers. I don't have any separate ones left. I should probably keep this one as we use a few of ours too! Let us know if you want it.
acdrivedisckit.jpg |
MiKe04gt
Posted: 22 Dec 2016 at 8:04am |
That's not the part I need. I need the cast iron part that bolts to the flywheel.
farmtoybuilder
Posted: 22 Dec 2016 at 9:21am |
I thought you broke the disc. As that's common! Have never broken a hub. I don't have any of them.
Mikez
Posted: 22 Dec 2016 at 10:07am |
Yea sorry I thought the same. I might be able to come up with a used one, have to look.
Jeff do you know if there all the same on the kohlers (10,12,14,16hp) Edited by Mikez - 22 Dec 2016 at 10:09am |
farmtoybuilder
Posted: 22 Dec 2016 at 12:06pm |
All same for the single cylinders!
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4079 |
Posted: 27 Dec 2016 at 3:12pm |
go to simplicitiymfg.com and go under support will take you to a place to type in your product number and serial
