Allis Chalmers 7060
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 7060
    Posted: 05 Apr 2018 at 10:25am
Hello,
For my 7060 I need a new floor mat. Because there is no floor mat to buy nearby, the shippingcosts are verry high.
Does anyone know the dimensions from the original floor mat?
Maybe I can cut it out of an large rubber.
If i know the thickness from the original and the pattern from the rubber.
Maybe someone has a picture? That would be great.
Will make it seem as most as original as possible.
Thanks!
Wot
AC: B / WD / CA / WC unstyled / U / 7060 / 710
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 11:56am
Wot...Here is what I did and you will never have to do it again.  I bought two 1/2 inch rubber cow mats and put it in.  full piece was large enough for the front portion and a small slab from the second mat for the back portion. I did it on a 200 but have a 7000 that is going to get one next. Cut it with a saber saw and hole saw. I had enough of the old mat for a pattern. Make yourself a cardboard pattern. textured finish, sound and vibration improvements, easy to clean.  Looks great. The only thing I would do different on the 200 is make left half and right half because of the battery box on the left side. You will have to extend the range buttons I think. I looked for some thinner industrial first but did not find what would work...Dale
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 1:43pm
Try taking a large section of an old cardboard box & lay it inside tractor floor to help form template. Then use cardboard template to create a new rubber floor mat of your choosing.
sodfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sodfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 7:13pm
There is one on ebay for $101 including shipping. I'm going to order one for my 7010.
