Allis Chalmers 7060 |
Wot ![]() Bronze Level ![]() Joined: 16 Sep 2009 Location: N Points: 160 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Apr 2018 at 10:25am |
Hello,
For my 7060 I need a new floor mat. Because there is no floor mat to buy nearby, the shippingcosts are verry high. Does anyone know the dimensions from the original floor mat? Maybe I can cut it out of an large rubber. If i know the thickness from the original and the pattern from the rubber. Maybe someone has a picture? That would be great. Will make it seem as most as original as possible. Thanks! Wot |
AC: B / WD / CA / WC unstyled / U / 7060 / 710
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1491 |
Wot...Here is what I did and you will never have to do it again. I bought two 1/2 inch rubber cow mats and put it in. full piece was large enough for the front portion and a small slab from the second mat for the back portion. I did it on a 200 but have a 7000 that is going to get one next. Cut it with a saber saw and hole saw. I had enough of the old mat for a pattern. Make yourself a cardboard pattern. textured finish, sound and vibration improvements, easy to clean. Looks great. The only thing I would do different on the 200 is make left half and right half because of the battery box on the left side. You will have to extend the range buttons I think. I looked for some thinner industrial first but did not find what would work...Dale
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3538 |
Try taking a large section of an old cardboard box & lay it inside tractor floor to help form template. Then use cardboard template to create a new rubber floor mat of your choosing.
sodfarmer ![]() Bronze Level ![]() Joined: 02 Mar 2018 Location: NORTH CAROLINA Points: 28 |
There is one on ebay for $101 including shipping. I'm going to order one for my 7010.
