Allis chalmers 7000
Gffarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gffarm Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers 7000
    Posted: 18 Nov 2023 at 4:25am
Does my 7000 have to be in park to start? Had transmission cover off to fix issue, and now doesn't start. Any reason for this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 5:29am
Nope. Safety switch on the clutch pedal (not easy to access) and one on the PTO lever, which you probably bumped with your body wrestling the cover on and off. Make sure the PTO lever is OFF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gffarm Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 5:47am
Already checked safety switches, even tried arching the starter which stuck engaged, replaced starter arched again, same result
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 5:56am
Well, if "jumping" at the starter with a screwdriver (to the 10gauge white wire) doesn't make it crank over, you have a starter issue or battery cables or batteries.
