The Forum Parts and Services Unofficial Allis Store Tractor Shows Serial Numbers
Allis chalmers 7000 Pulling Tractor
Jm_hall_471 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jm_hall_471 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers 7000 Pulling Tractor
    Posted: 27 Jun 2022 at 7:03pm
If you are pulling a allis 7000 do you remove the 1 2 3 power shift out of the transmission if you are pulling in light limited super stock. If so how is it done
Thank you for the help in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2022 at 7:42pm
Light-Limited-Super Stock to me means over 1,000 HP, so yes, that clutch must go. A coupler needs to be fabricated to connect to whichever range you want...under drive-direct drive or overdrive. Approx 20% jump between each range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jm_hall_471 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2022 at 8:00pm
Much appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2022 at 9:56pm
Welcome to the forum. We like to see pictures and hear about your orange tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2022 at 10:00am
Always heard the 7000 was a one of a kind with the Powershift setup it had- and they were based on a 200 tractor- so the powershift can be removed , interesting
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2022 at 6:12pm
All original Power Director tractors that were hydraulically activated were two-speeds, direct-drive (high) and 20% under-drive (low). The model 7000 tractor had a 20% over-drive added to the concept. The whole torque housing is completely different with this new design and the PTO is fully independent and 540/1000 RPM only. Amazingly, the length of the torque tube is still 39 inches, the same as previous models (180-185-190-200).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jm_hall_471 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2022 at 9:05am
Is there any info on how to make a coupler of some sort for the powershift gears. Thanks
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2022 at 2:29pm
Hey Doc , ever do any comparison with the gears between the 180 / 200 vs the 7000 as to a retrofit ?   I noticed the 7000 do not use the bushings on the pinion...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2022 at 7:31pm
You know, it's been since 1977 that I had my first maroon 7000 transmission apart.   It had a bad pinion seal transferring oil one way or the other. I had my second one apart in the early 90's for reverse gear on the counter shaft having the teeth all chewed up from a heat treat issue. They have been  that good !! Two 7000 transmissions in 40 plus years !!  So, no I did not compare parts to the 180-200 transmissions, but I know the gears are all wider and I'm thinking the inner diameters may be larger too.  The width would be the deal breaker in the end I think.
zero61 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zero61 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 5:02pm
I’ve been running a 1980 black belly for the last eight 8 years I’ve done a lot of changing inside of my transmission tried to upload a picture but it wouldn’t
Post Options Post Options   Thanks (0) Thanks(0)   Quote zero61 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 5:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 5:15pm
If I remember, this one has a 5.9 Cummins which does a great job !
Post Options Post Options   Thanks (0) Thanks(0)   Quote zero61 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 5:24pm
Yep 5.9
Blew up 2 301 motors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 10:52pm
Welcome to the forum. Thanks for sharing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jm_hall_471 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 12:32pm
We are lost at the transmission. How did you build the transmission to hold up to the power?
Post Options Post Options   Thanks (0) Thanks(0)   Quote zero61 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 1:52pm
I have no problems sharing what I’ve done to my tractor. send me an email at zero61puller@gmail.com
And I’ll shoot you my phone number. and it’s a whole lot easier to send pictures and tell you how I did it on phone
Post Options Post Options   Thanks (0) Thanks(0)   Quote zero61 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 2:10pm
Or go to Facebook
Look up Robert Clark
Or tuff times pullin team
Get me that way!!
Sending pics on here is impossible on a phone…
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 5:00pm
I have no idea what JM hall is trying to do, but I am used to LLSS tractors running road gear, which is direct drive. If you want to go faster than that, then you are getting into the custom gear making area. A true model 7000 drive line would have room for an over-drive box right under your feet where the Power Shift clutch assembly was. Road gear in the tranny with an overdrive speed-up ahead of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zero61 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 5:06pm
Yes!! A 7000 is 27.885 to 1. Strait thru in 4th.
I had two gears made on input and runs low side. 25.4 to 1 is result. Only have 1 gear but hey I’m a do it yourselfer low budget puller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 5:32pm
7000, 200, 190XT all the same ratio in road gear.....27.88 to 1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zero61 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 5:56pm
I’ll do my damned to try and put on here with my granddaughter help to show how I done it..
Lot of 7000 to use as pullers
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 6:27pm
Wonder what chassis Bernie Platz has under him ? Its 7000 sheet metal and I believe a 426 with multiple turbos - I think this dont know for sure ; curious if its a 7000 driveline ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2022 at 12:50pm
It was a 190 rear-end 2 years ago
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 9:25pm
Power through trans. is no problem, gears will hold. Weakest point is ring gear moving away from pinion. This can easily be fixed by a girdle around right bearing housing and reinforce out side of bearing housing.                 MACK
