Allis chalmers 650 backhoe attachment
kris holden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kris holden Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers 650 backhoe attachment
    Posted: 24 Jan 2011 at 7:15pm
i have just bought a 650 allis chalmers backhoe attachment and i am wondering about the hydraulics. how many gallon per minute pump i need and how big of a tractor will i have to put this attachment to. how much does the whole attachment weigh??? what are yalls recommendations for what size tractor and hydraulic punp needed.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 11:23pm
I have one also and it came off a HD4 with I believe a 24 GPM pump at 2200 PSI
1" lines from tractor to valve body .
 cesna rotary piston for swing motor, that unit was also used on MF and some IH units.
hope you do not have to work on that as it's a real bear to get the seals in right on shafts.
Weight I would say is around 2500 or so
If you replace any of the ball joints on lever controls Simplicity parts for the rod ends work as I got mine from AC dealer out of lawn mover parts bens.
If you know anyone looking for one mine is for sale also.
Edited by Coke-in-MN - 26 Jan 2011 at 11:27pm
