Allis Chalmers 540 rim needed
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 540 rim needed
    Posted: 15 Dec 2022 at 11:00am
Got a buddy that is needing a rim for his AC 540.  Tire size that is on it is 1200 16.5.
We found a 15 inch rim but of course just will not work.  Let me know if you have one,
where you are (zip would be good) so we can figure possible shipping price and how much you would want for the rim. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2022 at 6:07pm
Den... does it happen to be 6 bolts on 6 inch circle ?   This one is 8.5 inches wide, should handle a 12 inch tire.
Edited by steve(ill) - 15 Dec 2022 at 6:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2022 at 6:19pm
Thanks Steve, I passed the info on to my buddy.  That's more of a lead than he had.  Den
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2022 at 7:57pm
tell him in addition to the 16.5 inch dia... he should know the number of bolts, the diameter of the bolt circle , the center hole diameter... and the Backset ( center plate from the edge of rim)...... they have several options in 6 and 8 bolt ... 8- 10- 12 inches wide...
Edited by steve(ill) - 15 Dec 2022 at 8:04pm
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2022 at 8:10pm
Den: if Steve's info doesn't work another resource is Miller Tire in Ohio.   The have both rims and have access to machined inserts for rims.  ~ Orangeman
This page was generated in 0.316 seconds.
