Allis Chalmers 5020 hydraulic pump |
wal1809 ![]() Bronze Level ![]() Joined: 11 Nov 2019 Location: Wallis Texas Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Nov 2019 at 5:13am |
Thanks for adding me to the forum.
I have an AC 5020 w/ a front end loader. The poor thing has taken a beating its entire life. It's been flooded, 6 feet under water three times. I owned it during the last flood. There was so much destruction, the tractor sat for months before I could get to it. I hired a mechanic who turned out not to be a mechanic. He said he drained the fluids but obviously he didnt. The front end loader worked as usual. Last weekend it stopped going up and down. It was also making a whining noise when the lever was pulled. This weekend I found the water in the fluid and the pump isnt even whining any longer. It does nothing when the levers are avtivated. Please post your thoughts. If you have a 5020 please post a pic of the pump. Do you have to air bleed these systems? Any information is appreciated. I am building a house on Matagorda island and this tractor is an essential part of the build. The whole reason it is out there is so I can unload pallets of materials off of a barge. My build is shut down until this thing is fixed. |
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 800 |
Did You Clean The Strainer
I have never worked on the hydraulics on this tractor. I dont even know where the pump or screen is located. I have googled my eyeballs out trying to find out where the pump is located.
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Buy a service manual, you won't regret it.
$25 to $80 Edited by chaskaduo - 11 Nov 2019 at 8:27am |
I bought one but it is limited. I will buy one you suggested. In the mean time any information is appreciated.
Go To Agco Parts Books .Com Use Guest User You Can Look Up Parts
For the Agco Parts Book
go to https://apb.agcocorp.com/ <- click on this link Scroll down to "Guest User" Click on "View Books ->" In Publication Type, put in 79005174 Click on the Parts Book that comes up
"AGCO ALLIS: 79005174 [PARTS BOOKS] 5020 / 5020 FWD / 5030 TRACTOR" And your in like Flynn. HTH I recommend the service manual and the parts book from Farmmanualsfast.com above I know nodda on the 5020 Edited by chaskaduo - 11 Nov 2019 at 11:38am |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8346 |
Ebay has them very reasonable,
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
The strainer is by your left foot when sitting in the seat. Transmission and hydraulic fluid is all in the same place added in front of the seat on top of the transmission. Hydraulic pump is at the bottom front of the engine. Not much of a job to change. I have always over filled with the loader. The oil level check plug is on the right side sitting in the seat. Edited by Dick L - 12 Nov 2019 at 3:52pm |
herm0016 ![]() Bronze Level ![]() Joined: 18 Jun 2019 Location: Longmont, CO Points: 22 |
you can get a pump on ebay... you have never changed the fluids after the floods? sounds like you need to clean/inspect the bypass valve as well.
5020 MFWD Power steering
